Beetle custom spray added and a new set of wheels
- Bratjie
- What model do you have?: 74
- Facebook: https://www.facebook.com/juan.buter
- Has thanked: 3 times
- Been thanked: 5 times
Just for a fresh look, got creative with my paint gun
Photo's dont really capture the ghost glint in the pearl but anyhow,
Esté robusto, ser fuerte!!!!
73 Beetle project
73 Beetle project
- dubster
- Been thanked: 3 times
Re: Beetle custom spray added
hi bratjie
dit lyk baie mooi ek like rerig jou beetle...
is dai heads toe nog reg?
1974 1300tp type 1
kart kraft 1717cc buggy
- Bratjie
Het nognie die heads opgesit nie, het toe n ander engine oorgedoen maar ek's seker ek gaan hulle binnekort nodig kry, thx's. Hoe's die pyp, oraait?dubster wrote:hi bratjie
73 Beetle project
73 Beetle project
- Dazz
- Has thanked: 2 times
- Been thanked: 4 times
dit lyk baie schmaaart...het jy die area eers geskuur?
Measure twice CUTonce.
1975 Kombie
1979 Kombie
W203 C320 CDI
'68 Austin Cambridge A60
Looking for a kombi project
1975 Kombie
1979 Kombie
W203 C320 CDI
- hitlers revenge
- Been thanked: 36 times
That looks very cool.
- slak
- Has thanked: 7 times
- Been thanked: 32 times
dis nou iets anders dit lyk baie cool wanner kan ek my kar bring
U Only Live Once Right !!!
- BUGGOFF
- Pushrod
Nice, i like the checkered effect on the deck lid. do you have any before and during pics?
- CooP
- Clutch
- Has thanked: 13 times
Too lovely
I'd also like to see before and during pics...
Size does matter
- Bratjie
Just kidding guy's, sorry I have no during photo's but I'll explain a bit
The bonnet and engine lid was already painted so that stayed the base, I wet sanded with 1500 grit paper to rough out for the new paint to stick. The bonnet was tricky, used 5mm fineline tape that you can get from any paint shop and layed out the flames by hand, like I said it's tricky because left and right images must look very alike, next I masked out the areas that were going to stay the original colour and cut it out using a sharp utility knife, removed the tape were paint is to be applied and sprayed 2 light coats of pearl mix. Then clearcoat, wet sand with 2000 grit and polish.
The engine cover was easier, I covered the entire lid with masking tape and with a pencil drew out the images I needed, then cut out the parts that needed to be painted and sprayed, also it was first wet sanded like the bonnet, removed the masking, wet sand with 2000 grit and polished.
Easy hey ???
73 Beetle project
73 Beetle project
- CooP
- Clutch
Ummm okay. Easier said than done methinks. Really nice job though, well done.
Size does matter
- Bratjie
I will make sure to take pic's of each step when I do the V8 Beetle, that will be a complete flame over body but with much more details and shadowing, promise ok?
73 Beetle project
73 Beetle project
- Hloni
- Has thanked: 14 times
- Been thanked: 11 times
Please tell me about those rear round lights.
Am l correct if l said those rear fenders are widened? Did they come with the bug, or you sourced them?
Great paintjob by the way!
- Bratjie
The round lights are just normal trailer/truck lites with modified tail & stop lamp, flickers you buy as is but theyre not very bright, therefore the modified square mist lights for additional brake lights, will fix soon though, the fenders are fibre glass and have been traveling with me for years before I put them on this bug.Hloni wrote:Please tell me about those rear round lights.
Thanks for the compliment
73 Beetle project
73 Beetle project
- splitfan
- Has thanked: 46 times
- Been thanked: 26 times
Dont be modest it takes a huge amount of effort to pin stripe , Flame, or do any "fancy" painting Well done !
- Hloni
Uhm...please give us another shot of that rear! Man, those are fine "truck lights". They look smaller than the usual - was suspecting them to be from AC Cobra or something like that as they look 'sunk' - just checking the black trim on themBratjie wrote:The round lights are just normal trailer/truck lites with modified tail & stop lamp, flickers you buy as is but theyre not very bright, therefore the modified square mist lights for additional brake lights, will fix soon though, the fenders are fibre glass and have been traveling with me for years before I put them on this bug.Hloni wrote:Please tell me about those rear round lights.
