ok...
Wikepedia...
In 1971, alongside continued production of the "standard" Beetle, a Type 1 variant called the Super Beetle (also known as the VW 1302 from 1971–1972, and VW 1303 from 1973 onwards) featured MacPherson strut front suspension and a redesigned front end. The new stretched nose design replaced the dual parallel torsion bar beams which had compromised trunk space and relocated the spare tire from a near vertical to a low horizontal position. The redesign resulted in a tigher turning radius despite a 20 mm longer wheelbase, and a doubling of the front compartment's cargo volume. As with previous models, air pressure from the spare tire pressurized the windshield washer canister, in lieu of an electric pump.
1972 Super Beetles had a slightly larger rear window, larger front brakes, and four rows of vents (versus two rows previously) on the engine deck lid. The tail lights incorporated reversing lights. The "four spoke" steering wheel and steering column were re-engineered to the "energy absorbing" design for better crash safety. A socket for the VW Dealer Diagnosis was fitted inside the engine compartment.
In 1973, the VW 1303 introduced a curved windscreen, pushed forward and away from the passengers, allowing a redesigned, "padded" dashboard to replace the pre-73 vertical dash. A 2-speed heater fan, higher rear mudguards, and larger tail lights were added. The changes to the heater/windshield wiper housing and curved windshield resulted in slight redesign of the front hood, making the 1971 and 1972 Super Beetle hoods unique.
For 1974, the previous flat steel bumper mounting brackets were replaced with tubular "self restoring energy absorbing" attachments, effectively shock absorbers for the bumpers, on North American market Beetles. These cars also got stronger "5mph" bumpers that added an inch to the length of the car. The steering knuckle and consequently the lower attach point of the strut was redesigned to improve handling and stability in the event of a tire blowout. This makes the struts from pre-74 Supers not interchangeable with 1974-79 makes.[30]
1975 brought the replacement of carburettors with Air Flow Control (AFC) Fuel Injection on U. S., Canadian and Japanese Beetles, a derivative of the more complex Bosch fuel injection system used in the Volkswagen Type III. The fuel injected engine also received a new muffler and the option of an upstream catalytic converter required on some models (e.g. California), necessitating a bulge in the rear apron sheet metal directly under the rear bumper, and replacing the distinctive dual "pea shooter" pipes with a single offset tailpipe, all of which make the fuel injected models easy to identify at a glance. Other changes were rack and pinion steering replacing the traditional worm and roller gearbox on Super Beetles, and a larger license plate lamp housing below the engine lid. The front turn indicators were moved from the top of the fenders into the bumper bars on European models, a portend of the "Euro look" style years later by Beetle restorers.
In 1976, the Super Beetle sedan was discontinued, and just the standard sedan and Super convertible remained. The optional "Auto-stick" transmission was dropped. 1976-on Super Beetles saw no significant engineering changes, only a few cosmetic touches and new paint options, including the "Champagne Edition" models (white on white was one example) to the final 1979 "Epilogue Edition" black on black, in salute to the first Beetles produced in the 1930s.
