simple draw through turbo setup.....with pics...
Posted: Sat Mar 13, 2010 10:00 am
by dubster
took these piucs of a buggy a while back, seems to be very simple to do and even thow its not the right type of motor in there it should work the same on a bug? maybe bugger or johanb can tells us more about these setups...but as ussual just had the pics and thought id share them....
Re: simple draw through turbo setup.....with pics...
Posted: Sun Mar 14, 2010 11:38 am
by johanb
I would have lifted the turbo a bit higher just to insure the return doesn't get clogged,,
With a SU carb that ride must be nice and smooth as well,, as the pics indicate nothing to it
Can't go wrong there or any other enjin
Johan
Posted: Sun Mar 14, 2010 1:40 pm
by ZeroAxe
johanb wrote:as the pics indicate nothing to it
Johan
For the non-bright bulbs in the box, Johan is referring to this..........
The tyre threads
Posted: Mon Mar 15, 2010 9:31 pm
by johanb
Posted: Mon Mar 15, 2010 10:03 pm
by ZeroAxe
Posted: Tue Mar 16, 2010 9:09 pm
by Bugger
Think I still got a 50mm SU laying around fot just such a job
But now adays the well sorted EFI is nicer but that set up works very well on a buggy or even in a bug as you can get it scuached in to a bug engin bay
Brian`s first 2.4 we ran with a suck through like that at a 13sec 1/4 ter in 1992
So any one for a SU
Posted: Thu Mar 18, 2010 7:20 pm
by johanb
I'll take it of your hands any day,, love my SU's for the turbo's, not as much power as the side drafts,, but very smooth,, you will swear it was factory fitted
Posted: Thu Mar 18, 2010 9:15 pm
by Bugger
Johan will keep you posted already had 2 PM`s with offers
Posted: Fri Mar 19, 2010 4:26 pm
by johanb
Seems like there are a few people more that will be building turbo motors
Can't go wrong there,, but they will have to use the 50mm on a 1900cc and up to about 2.4L (might try bigger motors as well),, otherwise a waste of a good carb
