Two sets of cast & machined aluminium 5 x 205mm (Beetle) pcd spacers, used to give your Beetle/Type3/Bus/Buggy a wider track width, or just for that
windgat look
One set (used) is 270mm wide each, and the other (brand new) set is 300mm wide each . R 200 per set, or R 380 for both sets.
