Crankhandle rear valance - will need extensive work @ R 300
'55 - '58 decklid - donor use only @ R 300
How about a RHD dash section? Two available.Set of "innie" vents @ R 300
Set of "outie" vents @ R 300
Each are actually the same, just flipped.
...and some other bits and pieces - let me know what you need.
All will need recon'.Stock 15" bug rims @ R50 ea.
I have some Bay' rims here too, and may have 2 Brasilia rims (R 200 set) too - will check and update here asap...
2 x 14" Rostyles @ R 400 set.
Set of '68+ bug headlights @ R 200
R 300This was bought for my dizzy, but it's wrong.
EDIT: This is for a late-model Kombi.
Code: DR8152HS
It's brand new, and I have the receipt for it too.
R 150
This coil has approx. 100km on it.
It got changed because it wasn't compatible with my setup.
It works 100% and was purchased new.
R 500 takes them - that's less than cost price.
Type 4 air filter @ R 200
R 300 set.
The white looks like a later addition - or touch-up.
The green is OG.
One is perfect, one has a very slight ding, and one has a larger ding near the center.
R900Stock-length Bugpack 3/4" BALLJOINT 'lowered' bar and is in as-new condition.
The only difference between a non-lowered and lowered bar is the way in which the bar is bent during manufacturing.
A 'lowered' bar allows more clearance when you drop the car, but works exactly the same way as a standard.
The bar will be supplied with urethane mounts - you need to supply the type of clamps you prefer to use.
The bar should be used in conjunction with a rear bar/camber compensator, depending on what your bug has - s/a vs. IRS.
...or will swop for a k&l stock-length 3/4" bar.
'68 - '73 'triangular' bug taillight innards and trim @ R 50
1 x late-model bug fender indicator (the large one) @ R 150
R 250Urethane bushings... [NEW]
Outer balljoint beam bushings; red (x4)
----------Sorting out some old spares in the garage and came across these Dunlop Ultra belts...
Did some Googling and et voila, we have the following:
034 260 849068 260 849
Volkswagen
> Golf 1985-92
Jetta 1984-92
Rabbit Convertible 1984-93
Scirocco 1984-88
Passat 1990-93
Audi
80, 1991-92
80 Quattro, 1988-92
90, 1988-92
90 Quattro, 1988-92
Coupe, 1990-91
5000, 1978-88
5000 Quattro, 1987-88
5000 Turbo, 1986-88
5000 Turbo Quattro, 1986-88
100, 1989-91
100 Quattro, 1989-91
200 Turbo, 1989-91
200 Turbo Quattro, 1989-91All 3 are genuine parts and are branded with the VW/Audi logos.034 903 137A
Seems to be for a Passat and Audi 80/100s. The late '80s/early '90s 'square' Audis.
Bay' door lock mechanism
R 150
R 200Bay' steering column and steering wheel
Steering wheel has some damage.
R 100Dual horns
R 200Type 4 headlights
Bay' pedal pans
I have a later pan for sale as well, for the same price'68
R 400
R 300'68 bug fuel tank
R 250Late bug/Golf Mk 1 ignition
Part number is 111.
These parts came out of my bug, they are in excellent condition, and everything works.
The ignition comes with a key, and there is no play in the barrels.
Double-arm indicator unit has been sold!
Miscellaneous
* '68+ bug cubbyhole lid; R50
* '68+ bug ashtray; R50
* '68+ bug fuel flap; R50
* '68+ bug speedometer; R150
R 300Single-arm bug indicator unit...
Miscellaneous...
Offers?I have no idea what these are off of...
R 400 ea.
DKW lights...
R 100Sansun wireless keyboard/mouse combo...
Mouse has rechargeable batteries.
R 50Age Of Empires: Gold Edition in original packaging (PC)
All in JHB.
If you need something else, ask - I may have it...
