Weber air filter adapters
Get your parts here
Got two of these Weber air filter adapters available, brand new @ R 100 each - it allows you to fit a round air filter to a DCD carb. Postage will be around R 25 for an insured parcel to any SA address, regardless if you take one or both :wink:
VW-rules
What model do you have?: '61 & '70 Buses
Has thanked: 10 times
Belgium
Re: Weber air filter adapters
Post by VW-rules »
I have a Weber 36DCD18 carb. on my Split bus. I would ideally like to use the standard bus air filter and connecting pipe (see http://www.eisparts.com/211129615E.html) instead of the home made unit I currently use.
My question is "Is the diameter for the filter the same as the Solex 34PICT carb.?"
If so, can I please have one. :D
I had more or less the same idea, but unfortunately the outside diameter of the the filter adapters (round part) are considerably larger than that of a Solex carburettor
Has thanked: 191 times
Been thanked: 487 times
go to a gasket and rubber shop and ask them to make you a rubber fitting that works as an adaptor.
One side has a hole the same size as the bus filter, other side have a bigger hole for the DCD
VW-rules
Belgium
Post by VW-rules »
Hi Pine
Do you still have the adapters for sale? If so I'll take one.
Christian
Farhaad
Post by Farhaad »
ill take the other one. will it fit a 38 weber. im experiencing the engine lid not closing. this might solve my problem and make a "mc gyver job" for the filter :D
thanx
pm me bank details
Farhaad
Post by Farhaad »
u hav a new pm :wink:
happy dayz r here again
thanx pine
Lindsy Vezasie
What model do you have?: 00, 07, 09
Post by Lindsy Vezasie »
Wow, I've been looking for these adaptors for so long now and only now have I come across them. I've just registered on this group.And I see now how old this post is. Are these by any chance still available, and if not, can someone point me in the right direction to acquiring 1 of these please. I'm contactable on 0734197334. What's app friendly too... Thanks guys
forcecooled
Post by forcecooled »
Hey, Lindsy
I might have one of these Weber 36 DCD airfilter adaptors in my collection - if you are still interested in buying one, call me and I
will get it out of the store for You.
- Bill
O72 11O 2643
benniekemp@gmail.com
What model do you have?: 1972
Post by benniekemp@gmail.com »
Good day
It seems like I'm the last one in the que, but I would really like one of these adapters if by any change some1 still have one. please let me know?
Or if you can tell me where to buy 1.
thanks
