67 Panelvan
Donovan D
Has thanked: 148 times
Been thanked: 73 times
Re: 67 Panelvan
Post by Donovan D »
The day has come.
Since the day I bought the kombi the rear hatch was not lekker. Today was the fixit day.
Took everything apart and all the bushes are completely worn. The PO did a fix by cutting the hinge and grinding it shorter instead of going to the root.
Now im stuck with a dodgy hinge.
If anyone has the two hinges that bolts on to the hatch PLEASE let me know.
Eugene
Has thanked: 59 times
Been thanked: 65 times
Re: 67 Panelvan
Post by Eugene »
Donovan D wrote: Sat Mar 07, 2020 4:39 pm If anyone has the two hinges that bolts on to the hatch PLEASE let me know.
I have but need it for my bus, so sorry dude, it's not happening :twisted:
Really can't believe how you made the seatcover believe she broke it :lol:
Been thanked: 539 times
Re: 67 Panelvan
Would it not be easier to drill bigger. and fit a tube bush in it by welding. ??
Camshaft
Been thanked: 107 times
Re: 67 Panelvan
Post by Haans »
It sounds to me that there are "samples" not too far from you ! Can you not copy them?.
A cold six pack and a friendly face can work wonders!!😎
Jdt1976
Has thanked: 114 times
Been thanked: 90 times
Re: 67 Panelvan
Post by Jdt1976 »
Haans wrote: Sun Mar 08, 2020 11:26 am It sounds to me that there are "samples" not too far from you ! Can you not copy them?.
For a six pack Eugene would make and fit it... :lol:
Donovan D
Re: 67 Panelvan
Post by Donovan D »
First prize will be to replace the hinges with new ones, seems no one makes these ??
Guess I will need to offer Eugene not one but TWO 2020 George Car Show stickers to borrow his to try and fix mine.
Has thanked: 42 times
Been thanked: 207 times
Re: 67 Panelvan
The 64-67 kombi rear hinges differ from those of baywindows. But, strangely, i think they are similar to those of type 3 stationwagons.
Donovan D
Re: 67 Panelvan
Post by Donovan D »
Dawie wrote: Tue Mar 10, 2020 9:58 am The 64-67 kombi rear hinges differ from those of baywindows. But, strangely, i think they are similar to those of type 3 stationwagons.
Yes, after doing some research I found that the bay window hinges will not work, but did read that the type 3 stationwagen is the same as the splitty.
Donovan D
Re: 67 Panelvan
Post by Donovan D »
Been a bit busy between the beetle and the kombi. Here is my attempt at repairing the hinge and the hinge stop which is clearly rotten
At the moment the hinges are being fixed up and new bushings are being made.
Not the best but seems to be in. I can probably clean it up a bit more and smooth it out.
Still need to weld the stop plate, will do that after a trial fit of the hatch.
Camshaft
Re: 67 Panelvan
Post by Haans »
Don't youjust love itwhen a plan comes together !!............sometimes 😉👍
Looks great,...just a lick of paint and uncle Bob could be your aunty !!
Donovan D
Re: 67 Panelvan
Post by Donovan D »
Another job done. Got some new bushes made and started assembling the hinges.
Getting the springs back in was a lot easier than taking them out.
The hatch opens up a lot more than it used to and closes nicely. Should've done this when I got the kombi.
The next repair is clearly visible in this picture
Eugene
Re: 67 Panelvan
Post by Eugene »
Donovan D wrote: Sun Aug 02, 2020 5:10 pm The next repair is clearly visible in this picture
Oh good....going to restore the bus? :twisted:
Donovan D
Re: 67 Panelvan
Post by Donovan D »
Took out the engine to clean off all the Tankwa sand.
What can I use to pressure wash the motor with, water and some clean green or paraffin?
Been thanked: 487 times
Re: 67 Panelvan
clean green with water.
I wouldnt use pressure, you've got no control as to where the water goes.
Also keep the water away from the pulley as it might go into the case
