Another volksrod
- What model do you have?: 1974
Another volksrod
Hi there here is my beetle be nice now plz
as can see it needs a lot of TLC but going to turn in to a Volksrod if i can get out of there by Friday, as the grass is holding it and my mazda could not tow it out, then we will start cutting the roof.
also looking at buying a 1969 beetle all original including the 1200 motor. and interior.
- vader
- Has thanked: 9 times
Re: Another volksrod
Well it has less rust than the DarkSide.....
Yes,but not more grass!vader wrote:Well it has less rust than the DarkSide.....
jip unfortunately tried for and hour with my car to get out but couldn't going to get tractor this weekend to move the car.
,,,,,___,,,,,
|,,,/___\,,,,|
|( o / ! \ o )|
_'''''¯¯¯¯¯¯¯'''''
|,,,/___\,,,,|
|( o / ! \ o )|
_'''''¯¯¯¯¯¯¯'''''
Got the mags this weekend.
The rear R16X55X255 front R16X55X205.
o and brought my Merc back from Kimberly as well had to tow it and could get max speed of 60 on up hill and 80 on straight poor Mazda etude
,,,,,___,,,,,
|,,,/___\,,,,|
|( o / ! \ o )|
_'''''¯¯¯¯¯¯¯'''''
|,,,/___\,,,,|
|( o / ! \ o )|
_'''''¯¯¯¯¯¯¯'''''
Compomotive Fuchs wheels!!!!!!!!!?????!!!!!!!!
Where on earth did you find these puppies?!
I want!!
Got them from my Uncle and he got them of a Cortina bakkie .......
he want R5000 for it but not sure if that what I want he kinda pushed me into taking them. I just like the idea of the huge rear wheel size.
,,,,,___,,,,,
|,,,/___\,,,,|
|( o / ! \ o )|
_'''''¯¯¯¯¯¯¯'''''
|,,,/___\,,,,|
|( o / ! \ o )|
_'''''¯¯¯¯¯¯¯'''''
Cool!! I would take those wheels in a heartbeat, unfortunately I only have steel wheels to swop for
Na want Mags for my rod not steelies don't want to go rat rod but if i get R4000 will think of letting go.
,,,,,___,,,,,
|,,,/___\,,,,|
|( o / ! \ o )|
_'''''¯¯¯¯¯¯¯'''''
|,,,/___\,,,,|
|( o / ! \ o )|
_'''''¯¯¯¯¯¯¯'''''
- What model do you have?: '68 Beetle, '72 Bus
Gr8, always like to see a beetle getting a new lease of life. Just don't let the grass grow under your feet. Hehehe
Isn't that what you'd expect from VW?
Just beetling along
Just beetling along
Just quick q can i get the windscreen cut or do i need to let a new one made to fit the chopped roof. I know the windscreens have that plastic bit in for the shatter proof but don't know if this is same here i can't see why not and that might be a problem.
,,,,,___,,,,,
|,,,/___\,,,,|
|( o / ! \ o )|
_'''''¯¯¯¯¯¯¯'''''
|,,,/___\,,,,|
|( o / ! \ o )|
_'''''¯¯¯¯¯¯¯'''''
- Barry
- Single Port
- Been thanked: 12 times
They can be cut - side and rear glass is tempered and can't be (although you can have flat tempered glass made up to templates)
Windscreens (laminated) are often tricky to cut especially older glass - they say if you get one good one from 3 attempts you're doing OK
Barry
I heard about a technique with 'cutting' glass where they mask the part that needs to be saved off with something, and simply sandblast the excess glass away?
- bugspray
- Floorpan
- Has thanked: 24 times
- Been thanked: 16 times
Maybe i watched too many b list spy movie's, but cant you get it diamond cut, or something to that extent?
