Blitzkrieg wrote:What are your plans for the car? Chassis off resto?
Baring serious happenings... YES!!!
I've already downloaded the correct wiring diagram for her, that to will be replaced.
The basic plan is as follows:
The items are not in any particular order at this point and the plan is not totally complete as laid out here.
Phase 1. Disassemble and mechanical.
1.1. Identify what needs to be replaced.
1.2. Identify what needs to be repaired.
1.3. Replace and repair all identified items.
1.4. Get engine re-built.
1.5. Get the gearbox Buggered.
1.6. Get the pan sorted. (Replace pan halves if budget allows).
1.7. Get suspension sorted, including new king and link pins. This includes sand blasting and powder coating as well as new shocks.
1.8. Manufacture and install new break and fuel lines.
1.9. Overhaul complete break system. (Full disk break conversion as and when the budget allows.)
1.8. Bag and tag everything with photos throughout the whole process.
Phase 2. General Body and exterior (This will be outsourced)
2.1. Get the body taken down to bare metal.
2.2. Get the body repaired including dents and rust removal.
2.3. Respray. (Red, wet look if possible)
Phase 3. Electrical system.
3.1. Manufacture complete new loom.
3.2. Clean and refurbish irreplaceable parts.
3.3. Have all buttons and knobs manufactured out of aluminium. (As and when time and money become available.)
Phase 4. Re-assembly.
4.1. Procure all new rubbers.
4.2. Procure all new bolts, screws and nuts (In stainless steal only)
4.3. Re-assemble with proper assistance and outsourcing where required (to line panels up correctly).
Phase 4. Interior.
4.1. Complete new interior in A-grade vinyl as per original spec. (in black and red.)
4.2. New roof lining in milk-white.
4.3. Dashboard repair/replace.
4.4. Horn ring replace. (Already sourced a new one, thanks Rui).
Phase 5. Get RWC and other required paperwork.
5.5. Just do it.
5.6. Get the personalized number plate N0T4S4L3 (if I ever have money to blow on this kind of thing)
Phase 6. Enjoy it.
6.1 Go to every car show and blow peoples socks off.
Yes, I know I'm in this for the long-haul.
I can only persevere and do my best.
All things considered, I do stand a high chance of success.
