I think most of us know how to balance pistons (they must all weigh the same, right) but from talking to various people, it seems a lot of us don’t understand that Con Rods need to be balanced a little differently
If you just grind a little away from the heaviest rods until they all weigh the same (very easy) you may in fact be putting your rods more out of balance than they were before you started (“say what”) no really!
With rods, you need to do what is commonly known as “end to end” balancing. With this method, you are basically going to match the weight of each of the small ends and each of the big ends separately
Why, because of something called reciprocal mass and rotating mass. The big end is going round and round, while the small end is going up and down. (Wow I made that sound simple!)
Look at this simple and exaggerated example
You have two rods, one weighs 610 grams and the other 600 grams you grind 10 grams from the first rod (let’s say it has a balance pad on the small end) and they are now balanced, yes?
Well no, if the first rod had a small end weight of 205 and a big end of 405 (610) and if the second rod had a small end of 200 and a big end of 400 (600) what you now have is one rod 195 – 405 and one rod 200 and 400. Although they are both now 600 grams they are in fact still out of balance.
Look at the pics of the balancing rig I had made up to do my rods (a picture is better than a thousand words)
Of course, this is not a complete explanation and I have plenty more pics, but it should get the ball rolling
Cheers
