"Eva-Ann"
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
Re: "Eva-Ann"
Measure twice..... Cut once
- Batman
- What model do you have?: 1971 Beetle 1600 TP
- Has thanked: 4 times
Re: "Eva-Ann"
Cut some new door cards yesterday ...
- Has thanked: 193 times
- Been thanked: 121 times
- Camshaft
- Been thanked: 107 times
Re: "Eva-Ann"
Looking good!,.....now try thecovering ,,....if younot to fussy with detail patterns,..youcan do it also.
Just take your time!,....and try the glue in a spraycan,.....seem to work well
Oh!!,...keep the car out the sun for at least a week once cards are fitted,....they say the glue must cure!!
- Batman
- Batman
Re: "Eva-Ann"
Glad to say that all rubberising has been removed. Now sanding and then some paint......Batman wrote: ↑Mon Dec 10, 2018 7:27 am The previous owner rubberised the interior for some reason. I thought that it was still in a good condition and that I would just clean it out and I would carpet over it.
But the weekend with some closer inspection I realised that it was lifting and that the one door is leaking, causing water to build up between the rubberising and the floor-pan.
- Batman
Re: "Eva-Ann"
Some before work in progress photos.
- Riaan.N
- Oil Seal
- Has thanked: 3 times
- Been thanked: 38 times
Re: "Eva-Ann"
Also recently done the areas under the front and rear seats.... it looked as if the battery had a baby powder party
What size is the Willard battery you have?
- Riaan.N
- Oil Seal
Re: "Eva-Ann"
Thank you. Does it fit nicely? Do you use the original bracket and ‘dop’?
When the time comes I will be replacing my battery with something a bit bigger (Ah) and also if possible with the recessed terminals.
- Batman
Re: "Eva-Ann"
Did some cleaning the weekend ... and cut a new rear seat backboard
- Batman
Re: "Eva-Ann"
Got some widened steelies for the rear ....
- Batman
Re: "Eva-Ann"
Sorted prepping the pan ....
- Batman
Re: "Eva-Ann"
Pan is actually good, just the usual part where the battery is, is a bit rusted. Will cut it out and replace the small section.
Must say a lot of elbow grease ... was a mission to get the rubberizing removed.
