Page 7 of 55
Posted: Wed Sep 12, 2007 8:15 am
by BARON
Hi 4agedub
Somewhat of the subject ,- is your dad the great rally driver from the early 70s?
thanks,
baron
Posted: Wed Sep 12, 2007 8:24 am
by 4agedub
I've actually heard this question a couple of times... no he is not.
My dad did race dirt oval track in the eighties and nineties, but not rallying.
Posted: Tue Nov 06, 2007 1:14 pm
by 2BugMe
Hey there...how is the project coming on??? Have any picture of the type of pipe work you intend to use???
Would love to know what a turbo setup would be like on a stock standard type 1 motor..
Posted: Wed Nov 07, 2007 10:41 am
by 4agedub
I'll probably start woring on her by next week again. Got my sleeves back today, so now I can finish off the engine
Posted: Mon Nov 19, 2007 10:54 am
by eben
Just to tickle you here's Dave Rowley's setup for his buggy:
Posted: Mon Nov 19, 2007 11:05 am
by Blitzkrieg
Boxer Turbos sound cooooool
Posted: Wed Nov 28, 2007 9:29 am
by 4agedub
Ok I finally got some pics again.
The beetle's back end with new firewall installed.
From inside the car
My digital dash installed
The boost boxes bolted on the throttle bodies. These still need a lot of work. Intake pipe size 63mm
My modified crank pulley, now with a 60-2 wheel mounted on it for the wasted spark setup.
New 94mm pistons and sleeves... decked to 1.3mm to give me 8:1 compression ratio
Here's some pics of the superlight flywheel I intend using again
My old MSD distributor... I doubt if this one will be used again
[/img]
Posted: Wed Nov 28, 2007 9:35 am
by calooker
Looking good. Plenty $$$$ ?
by Bugger
Cool man now not to long to go
by Blitzkrieg
I'm interested in that 60-2 wheel, what car did it come of?
Looking really good-Can't wait to see it in action...
Posted: Wed Nov 28, 2007 9:44 am
by 4agedub
Ivan at Volkspares got it made up for me and fitted it to the crank pulley. Now I can go completely distributor less.
Posted: Wed Nov 28, 2007 9:47 am
by Chris
4agedub wrote:Ivan at Volkspares got it made up for me and fitted it to the crank pulley. Now I can go completely distributor less.
Posted: Wed Nov 28, 2007 9:49 am
by 4agedub
Distributor less... Coil per cylinder, no more distributor. Like the new gen cars.
by Blitzkrieg
On the STF, I saw a guy mount a Ford EDIS trigger wheel similar to yours behind a type 4 fan...
Would like to try that when I do my conversion...
Posted: Wed Nov 28, 2007 9:50 am
by Chris
So you are making a Deek then
