1960 Beetle called Oupa
- What model do you have?: Golf mk1
Re: 1960 Beetle called Oupa
you cant just leave us hanging like that! whats happening with the engine and the final touches? looks really good man.
- Kafer74
- What model do you have?: Beetles
- Has thanked: 37 times
Oupa's Ticker (final)
I bought a gasket set from Rui to replace all the old gaskets on the engine. I took the engine to the "guru", Werner Alker, to replace the gaskets and assemble the engine. As mentioned in an earlier post, a pressure washer was used to remove most of the dirt and grime. The problem is that we didn't block off all the places where the water could go into the engine properly before we started cleaning the engine. As a result we could see the years worth of rust on the sleeves. When we removed the push rods we saw that they were eaten away by the cam. This meant only one thing, the engine needs to be opened so that we can look at the cam. Just when I thought things couldn't get worse we noticed a crack on one of the sleeves. Luckily we had a replacement sleeve.
At first Werner thought I would need a new set of pistons and sleeves but after he started working on them he mentioned that it might not be necessary after all. He cleaned all the pistons and sleeves and then he honed the sleeves. Werner then opened the engine and as was feared, the lobes on the cam was worn off. Except for the sludge in the engine caused by the water everything else looked ok. Werner said that this was the first time in his life where something that looked like a lost cause when he started on it, turned out to be a success.
I left the engine with Werner and he called me a day later to say that he has finished assembling the engine. I took all the tin pieces, generator, replacement exhaust etc. to him so that it can be fitted.
Fast forward a week later. Today 23 February 2015. Oupa's engine is finished and to crown it all off...Werner started it for me. I took a video of the event, the master has done it again. I am overjoyed ....
Enjoy the Ride
1970 Westie called Ben
- vw59beetle
- Has thanked: 39 times
- Been thanked: 40 times
Lyk goed sover. Ek sit op die oomblik by Werner en hy geniet die thread . Kan nie wag om die kar klaar te sien.
- Kafer74
NEW ROOF
I loaded Oupa on a car trailer and took him to someone in our club to install the windows with the trimmings. Apparently it is somewhat of a "craft" to fit the trimmings and I think it is also the reason why a lot of Beetles have window rubbers without trimmings. I will rather not say what I was quoted previously to have this done, which is why it took me so long to finally have the trimmings fitted. Upon my arrival I was told that the balck roof lining I had installed was not done properly and had to be replaced before the windows could be fitted. There was no other option and I gave the go-ahead. This time I settled for a white roof lining instead of the initial black. I must say the final product is awesome.
Now the windows can be fitted and we can start with the interior.
I hope Oupa appreciate all the trouble I am going through...
Enjoy the Ride
looks good... I am sure he appreciates it all. And will return the favour with many happy miles and many smiles...
- Kafer74
The windows with trimmings have been fitted.
Enjoy the Ride
- Kafer74
I have fitted some items back in the car. To find the right screws for the sun visor was quite a challenge. I still need to reupholster the interior but due to cash-flow problems I had to refit the original ones. The seats are all worn out and the boards of the side panels are torn. I will be using the originals as templates to cut out new boards and cover them with the old covers.
Enjoy the Ride
- Kafer74
Bowden Sag
Oupa had major clutch shudder when pulling away. According to the experts the flexible tube where the clutch cable runs through is supposed to have a "sag" or "bend" of just the right angle which will prevent the shuddder. For those who are interested, the whole scientific explanation regarding how this work can be found on the following website: http://www.thebugshop.org/bsfqbwdn.htm
I removed the rear tire and inspected the tube and found that it was totally straight with not even the slightest sag to be detected. So back to our local car guru, Werner Alker to set the "bowden sag" just right.
At Werner's place he fitted some spacers to create the sag in the tube but there was still a problem adjusting the clutch. Werner then discovered that the gearbox mounting was broken. The shudder was so bad that it must have broken the mounting which now needed to be replaced.
I made an appointment with Werner and two weeks later I arrived at his place and he started on replacing the mounting. It is a huge job because the engine needs to be removed, the gearbox, drive shafts and shocks loosened and then the gearbox needs to shifted back so that there is enough space to remove and replace the mounting. After that the whole process needs to be done but only in reverse.
Oupa is running again and the gearbox selection is as smooth as it can be on a 1960 model Beetle. Now I can focus on the replacing the rear interior panels.
Enjoy the Ride
- Kafer74
NEW SET OF BOOTS
I get a feeling that the tyres on Oupa are as old as the car itself. There are visible cracks in the treads and one of the tyres deflated without any visible cause.
So I bought him a new pair of boots, all shiny and new.
Out with the old and on with the new
Enjoy the Ride
- Kafer74
RUNNER BOARDS
I have replaced Oupa's runner boards but they are not very good quality and they also appear to be shorter than the original runner boards
Enjoy the Ride
Loosen the fender bolts near the running boards, ie the 1st 3 or 4 bolts on both front and back, then only tighten the running board bolts after fitting fender washers on both sides of the bolt and nut, then re-tighten the fender bolts.
Should now look right.
