Page 7 of 14
Re: Mild 1600TP Turbo engine
Posted: Fri Oct 21, 2011 7:54 am
by slak
Hi Bratjie
i don't see why u need a oil pump with filter if u have a full flow casing u only need in u'r
case the larger oil pump with the fullflow cover the oil cooler adapter sanwich is fitted in between
the oil filter housing and oil filter which lets the oil go to the cooler but u have a full flow system
so u don't need that either the extra sump IMHO is a must to have enough oil on hand to cool
and for the rest of the system
Posted: Fri Oct 21, 2011 11:35 am
by IMPI
The reason that turbo drains need to be higher than the level of oil in the sump is the fact that as the turbo spins it actually aerates the oil feeding it and there is a froth coming out at the discharge end this is the reason the feed has to be 1mm and the outlet 20mm plus. because of this froth struggling to displace oil in the crankase it is therefore desirable to have it exit above mean oil level. Porsche had the same problem with the 924 turbo with regards to drains so they simply put a tee piece in the return line which was connected to the highest part of the engine (the tappet cover) this allowed the return oil to expand and the consolidated oil to drain to the sump on a beetle this t could be connected to either the oil filler or an external breather box. I am not to wild about attaching a source of hot oil to the tappet cover I would like them to act as heat sinks drawing oil away. My 411 turbo had the drain coming from underneath the sump exiting level with the oil leve of the engine and that worked extremely well.
Posted: Fri Oct 21, 2011 8:32 pm
by Bugger
Is this motor going in a Beetle or in a Buggy
Have you built the Exhaust system already ? if not try and locate your turbo Gearbox side and Forward motion will also help the Turbo Drain Back to the Motor on Acceleration
and boost pipes will be shorter to the Intercooler(Personaly I will go Charge cooler) but intercooler is better than nothing
Charge coolers I think I paid R1500 from Turbo Toys last month for a Charge cooler
Oil Cooler Hunt the Scrap Yards for the Mercedes ones they are half the Size of a Rx 7 Oil cooler but 2 in Series will work wonderful
These oil coolers most of the older Mercs had then Right below the Radiator and you can Pick them Up for around R400@as mentioned thin and small and can fit above the Transmission with a Small scoop Plate to scoop air to them
Posted: Fri Oct 21, 2011 11:19 pm
by Bratjie
Bugger wrote:Is this motor going in a Beetle or in a Buggy
Hi Bugger, it's going into a beetle, the one Iv'e had for about 15 years, so no real cutting on my body allowed,
The exhaust is a tuck away from Dave Rowley as in the pic,
The turbo will stay where it is, I will fit deep sump and external oil filter to cure drainage problem with a vent system someone mentioned in another post,
Found an intercooler from a Mazda rotary, just the right size to fit where I indicated in a previous post (see pic), found an oil cooler as in the pic, was told that the oil cooler and intercooler can be fitted one atop of the other, first oil cooler then intercooler with a suck fan and scoop to help with airflow,
Piping to fro is a trial and error and a mod I'll have to tackle once every thing has found it's place
Posted: Fri Oct 21, 2011 11:39 pm
by Bratjie
Tonight I set the rocker geometry, made an adjustable pushrod, cut the cromoly's and fitted the 1.25:1 rockers. Not such a bad task, cut them with a normal pipe cutter and deburred, valve sttings are swchweet with enough adjustment left on the adjusters to go up or down, I believe loose zero is the setting but I'm going for .02 lash untill she's run in and I add boost.
I'm going to run her in without the turbo so all the originals are going on like fuel pump, 34 PICT carb and the old freeflow exhaust untill I can buy the sump, intercooler and oil cooler next month, hopefully she'll cut her teeth before I add boost, hopefully she'll run sweet with a liittle extra power due to the headwork and rockers and all the balancing, new pistons & sleeves and so on.
Hopefully fitting engine and startup tomorrow morning, it's 11H37 and I'm talking too much again, rest of the car also needs to be cleaned up and refitted after the respray, so lotsa work left,
back to the garage for me
Posted: Mon Oct 31, 2011 9:25 pm
by Bratjie
So, I put it all together and took her for a spin, she idles and rev's up very nicely but there's a lot of hesitation and misfiring when pulling off and accelerating, I tuned and played with timing and resetting the carb but she doesn't get any better so I left it to ponder about it some more, I think I may have a crappy carb ( old rebuilt) that does'nt want to play. Also thinking that I dropped the compression ratio to
(I guess about 6.9:1 ) so that could also be a big factor, I want to rebuild a good carb and try it on and see what happens. Sounds like she's either starving from fuel or overfuelling, lloks like some fuel is being sucked from the power pump nozzle when cracking her open,
Otherwise I'll jus wait to fit the inter and oil coolers and have a go at the turbo setup with the Dellorto.
Will keep you posted, anybody has some idea why she would perform so utterly sluggish?
Posted: Mon Oct 31, 2011 11:08 pm
by calooker
Running a stock carb?
Posted: Tue Nov 01, 2011 7:25 am
by slak
If it's only hesetating on acceleration then the pump jets might be too small
what are u'r jet sizes atm.
Posted: Tue Nov 01, 2011 6:15 pm
by Bratjie
calooker wrote:Running a stock carb?
Yes, running a stock carb just to run it in with, just did'nt expect power to be so weak, no idea what main jet size ( cant read the size), the power jet squirts a healthy jet of fuel down the throat, maybe I must just get the oil and intercoolers fitted and fit the turbo and DLRA CARB abd see what happens then,
Posted: Tue Nov 01, 2011 8:47 pm
by Bugger
Bratjie wrote:calooker wrote:Running a stock carb?
OK But you have not the Turbo in the mix
Check the Spray jet that it spray directly down out the bottom of the Carb when you crank it open by hand holding the Carb in your hand and adjust the spray jet according this will cause a big hesitation flat spot
Posted: Wed Nov 02, 2011 3:37 pm
That wasnt a thin line sump you had pictured... If I was you I woulldnt use a thin line sump, you want your oil to drain as low as possible. Thin line is only about 40mm deeper.
Posted: Thu Nov 03, 2011 6:51 am
by calooker
The CR will not cause the issues you are having, infact it's very close to the stock CR anyway.
Posted: Fri Nov 04, 2011 8:33 pm
by Bratjie
Posted: Sat Nov 05, 2011 3:33 am
Posted: Wed Nov 09, 2011 2:09 pm
by Bratjie
Can someone give me some cold hard suggestions please?
I'm going to cure the oil drain issue by lifting the turbo higher so I dont want the extra sump right now, I need to fit an external oilcooler and filter, what would be the easiest and cheapest route to do this? IOW two lines from the engine , one running to filter and cooler and the other back to the engine again without extra sumps, pumps, sandwiches, adaptors and other cocamamie add on's.
I want to get this thing airborne now
