My Project beetle - wish me luck !
JonnoDub
Oil Seal
Been thanked: 9 times
Re: My Project beetle - wish me luck !
Post by JonnoDub »
Finished the bootlid off today
Still need another coat on the bonnet
I swapped out the engine from my kombi which looks like a single port 1500 which was way underpowered for the bus, I think it will better suit the beetleImage
Now theres enough space to put back the piece I hacked out for the type 4 engineImage
"A journey of 5000 miles starts with a single step"
JonnoDub
Oil Seal
Post by JonnoDub »
Its been a while since Ive posted anything . The beetles going ok, looks like I may need to overhaul the engine sometime, put some extra bits and so on it.
The wheels have changed (again) and some EMPI bits have been added.....More pics to follow.
looks interesting. Was going to comment about the rims needing a little paint, but then I saw your EMPI post - now we really need more pics!!
Looking good, will be good to see the Beetle with new wheels.
JonnoDub
Oil Seal
Post by JonnoDub »
Some more pics
with steelies
JonnoDub
Oil Seal
Post by JonnoDub »
Since my last post Ive been having problems with the front suspension, So it was time to redo all the joints and went for a front disc brake conversion and lowered the front with adjusters. Due to the new disc brakes been 4 x 100 pcd, it was time to change up the wheels and got 2 adapters for the rear. I decided I want to keep the wheels OEM and went with a set of 1981 Jetta 13 inch rims. Brakes have now been bled and its time to set the wheel alignment. This is going to have to be a DIY job as the places around here dont want to touch my beetle because its lowered and does not have the period correct rims.
Heres a pic of her with her new shoes.
she is looking good.
JonnoDub
Oil Seal
Post by JonnoDub »
Thanx Tony Z , still need to do something about that engine , are you back yet?
yes, arrived a few days ago
JonnoDub
Oil Seal
Post by JonnoDub »
I just found some before and after pics of the rims
example
before
repainted with 2K rim silver
Whitewall and rubber installed
Anyone know where I can get hold of the trim rings?
small world, I bought those red steelies and caps from you two weeks back.
Do you need the 13 inch trim rings?
JonnoDub
Oil Seal
Post by JonnoDub »
Howzit man, small world really....... , yes 13 inch trims , but im looking for the period correct 1 for the rims
JonnoDub
Oil Seal
Post by JonnoDub »
So for Ages I have been looking for an original 1600S badge for the the deck. I have literally been looking Solid for the last 2 years. I finally found one a few weeks ago by a guy that had 2 of them.
He let me buy the ugliest 1 lol
The swambo decided to give it some tlc
JonnoDub wrote: Wed Apr 11, 2018 7:48 am ..... , yes 13 inch ... rims
Will look good, but you do know you will effect your top speed, and if you push it on the open road, you will over rev the aircooled motor and kill it.
On the other hand, you will have a killer pull-away.....
JonnoDub
Oil Seal
Post by JonnoDub »
retrovan wrote: Wed Apr 11, 2018 9:59 am
Hi again , yes I will not be pushing the car hard as I realised the 13 inch revs can be high. I normally go max 80-90 km/h anyways will try to keep the speed low n slow
