66 Feuerwehr Project
- What model do you have?: 72 Early Bay Deluxe
Re: 66 Feuerwehr Project
Hey bugger.. check this out, maybe u can use this..
Dennis Fire Engine Head Lamps (Pair)
http://barnfinds.co.za/index.php?main_p ... cts_id=211
Kuven Aramugam
E-Mail:
Contact #: 083 716 4455
Current Ride:2003 Golf 4 GTI
FRC - 76mm ATP DP and 63mm Wildcat Zorst - Forge TIP - Forge DV.
Project - '72 Early Bay Deluxe
E-Mail:
- DR WATSON
- Clutch
- What model do you have?: 56,66,69,73,FLEET
- Has thanked: 7 times
- Been thanked: 4 times
Bugger, I spoke to Jan at SA Emergency & Fire about some old fire engine goodies, suits ,helmets, reels etc. He said we must make a turn at his place in modderfontein and we can discuss this over a couple of cold ones. Let me know when you want to go and Ill organise with him.
- DR WATSON
- Clutch
Ill arrange it for one afternoon from about 15h00.We will stay until we manage to get what you need
Just in case we need to negotiate
- beetlefanatic
- Has thanked: 8 times
- Been thanked: 12 times
Some inspiration for the project.
Dankie Oom
I actually need to update this thread need to get my Pictures out of the stuff I got for the Project
And it is no more a Panel van but I am going to use the 11 window 63 bus I got for this project
- 69bug
- Has thanked: 4 times
So when do we get another update?
Ye sorry guys have to update this one and the 66 Squareback Elvis
I managed to get a 1969 Baywindow front suspension with ball joints and wide five wheel lugs
Advantage of using the bay ball joint suspension is that it bolts straight up to the Split bolt patern and it gives the split a Lift of 2 1/2 inches which I want to get the
Roughed off road look for the fire bus. And it gives the bus a slight softer ride with the ball joints and as I want to keep the 15" Bus rims wide five,is why I dont want to use the bay with disc brakes then I need to make adapterplates for the wheels
I am happy with the drum brakes when done right as this will be used rarely
