4agedub
Been thanked: 13 times
Re: My Type 1 turbo circuit racer (update pg43)
Post by 4agedub »
Clutch installed & Engine is in, exhaust manifold wrapped and installed. Next step... install the turbo and do some oil plumbing. :)
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
4agedub
Post by 4agedub »
Some progress.
4agedub
Post by 4agedub »
Wow Louis, that is looking good.
Can I make 1 recommendation? Rather run the turbo's oil drain to the #1&2 cylinder head, it drains quicker and easier than 3&4
4agedub
Post by 4agedub »
Thanks Tony.
I'm not too worried about the oil draining, the idea is that the excess oil will help cool the nr 3-4 cylinder head for what it is worth. :)
Wentzel
Post by Wentzel »
Looking great Louis let us know when you will be taking it onto the track I would love to see it in action.
Oxyboxer Project
4agedub
Post by 4agedub »
Thanks Wentzel will do.
4agedub
Post by 4agedub »
Fuel lines are almost done.
1/2" from main tank to surge tank
3/4" from surge tank to fuel filer and fuel pump
1/2" to the rear to be splitted into two 3/8" sections
Fuel pressure regulator still needs to be fitted... it's getting crowded quickly and I have not found a spot for the turbo water cooler yet :?
splitfan
Has thanked: 46 times
Been thanked: 26 times
Post by splitfan »
looking verry good there ! can you show us a pic of where your oil return fits in the t/c , I have had to move mine (twice) as the moving rockers would restrict the return and then cause the turbo seals to blow :(
4agedub
Post by 4agedub »
The oil return is on the 3-4 valve cover, the turbo drain is about 100mm higher than the cover and is fed with a 5/8" pipe. The engine is dry sumped which helps for the oil volume in the valve cover.
Ideally you want the oil drain in the 1-2 valve cover as it drains easier due to the crank rotation.
splitfan
Post by splitfan »
Thanks for the pic :) I also have my drain running to the 3/4 side (this is the side the turbo is fitted)
I now have the return in the centre of the t/c /rocker arm , the turbo is getting a rebuild so lets hope thats sorts it out .
4agedub
Post by 4agedub »
What size pipe are you using for the oil drain?
splitfan
Post by splitfan »
Return line has been "upped" twice currently about a 12.5 id on the return and its short about 30cm max :zhelp:
4agedub
Post by 4agedub »
1/2" should be good. Have you restricted the oil inlet to the turbo?
What brand turbo are you using?
splitfan
Post by splitfan »
Only restriction in the line is a t piece for pressure gauge ,feed id if i remember is a 6mm, ahh the million $ question , the make of the turbo is suspect but on the 2nd rebuild I had Garrett internals fitted , I heard today the turbo is ready for collection i kinda made up my mind to change the turbo to a garrett/TNetics but I want to be sure im not gonna stuff the new turbo .
