Helena..my 1960 VW Karmann Ghia
- What model do you have?: 1957 Oval
- Has thanked: 42 times
Re: Helena..my 1960 VW Karmann Ghia
Kombiman,
Will buy that VDM Steering wheel to loosen some finances for your lovely Ghia....
Regards
51Splitfanatic
Regards
51Splitfanatic
- Cogita
- Oil Seal
- What model do you have?: 63 Beetle
- Facebook: https://www.facebook.com/roscoe.jacobs
- Has thanked: 67 times
- Cogita
- Oil Seal
51splitfanatic wrote:Kombiman,
Regards
51Splitfanatic
Haha!!! Will keep that in mind
- Cogita
- Oil Seal
karmann.pierre wrote:Wish Mine was that complete when I got her "1958 lowlight" but now have majority of parts excluding bumpers and seats. Good luck with the restoration. I will post pics of mine as soon as I learn how to
It actually wasn't that complete...Basically a body on wheels with a motor that had a bearing knock
parts I had to find were front and back screens, driver door glass, headlights, driver door handle, engine bay section, front bumper, headlights, front seats.
Still needs:
-Side mirror
-Rear view mirror
-Sunvisors
-Original headlights
-Carpet
-Sill plates
-And seats to be restored
Aswell as beading
- Cogita
- Oil Seal
Hi Guys
Its been a while...
Here are some recent pics of Helena
Its been a while...
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
- white_356
- What model do you have?: Splitty,356,Westy,KG
- Has thanked: 23 times
1960 Karmann Ghia
1960 Split Window Kombi
1969 Beetle 1500 LHD (Project)
356 Speedster Replica
1970 Lowlight Single Cab Bay
1972 Westfalia
1989 Syncro (2.5 Suby)
2017 VW T6 Transporter 4motion
1972 Westfalia
- Cogita
- Oil Seal
Recent pics
She looks good Roscoe!
- Cogita
- Oil Seal
Hi guys
After standing for more than a month due to bad metal fuel line and starter, she is back on the road
We went the route of running the new metal line on the passenger side of the tunnel connected to the rubber hoses on both ends.
Regards
Roscoe
Regards
Roscoe
- Pushrod
- Has thanked: 141 times
- Been thanked: 100 times
It is probably easier that way, but more chance of corrosion, as with the brake line on the driver side. Also, dangerous in case of any leaks. The safest would've been to run it through the tunnel, or even under the car, if you have to.
- Camshaft
- Been thanked: 107 times
Cogita,....it takes big nuts to stay on it !. And Helena is looking good. My Haans isat the upholsterer for headlining and carpets.
Will however not say a word to Him ,.... just in case he gets a notion?
Regards Nick
Regards Nick
- Cogita
- Oil Seal
[/quote]
I would have loved it to run through the tunnel exactly like the original, but I heard its a nightmare to remove the original from the tunnel.
[/quote]
- Pushrod
It is done the same way you would replace old cable casings in old Vespa/Lambretta scooters. You attach the new line to the end of the old one with proper duct tape and slowly pull the old one through from the front of the car. I've done this on my Beetle.
- Cogita
- Oil Seal
Thanx so much for the info
Definitely going to change it.
Regards
Roscoe
Regards
Roscoe
