Hr - you getting into the early morning habit ??
Well what with the Grand Slam day did not have a full go at the buggy this weekend
But before the event and yesterday morning
Cleaning the shafts and the gearbox - a wee bit of the speed wheel with the grinder and then a blast with some sand to give a good key for the paint
also cleaning the front tubes of all the grease and sand that got in there
Got all the drums and pads back from Grand Slam - so brakes all done just need to assemble
Job list for the week
Hone the king and link bushes and polish all the pins
Have 2 sets one from the manx and the other from the donar pan - hope to get one decent set out of the lot
Front axle tubes spent the day in the sun to "heat' up the grease and then a blast with the high pressure washer - this will happen a few more times to get most of the gunk out and then will have the jeyes soak to clean it out good and proper
Finish off the blasting of the box
Paint up all the clean bits with some chassis black
will also paint up the rims while I have the mix out
Hopefully some fresh sand will arrive that I can finish off blasting the rest of the pan
Need to also fit the pipes in the tunnel
Project is nearly there
Just have to keep reminding myself take it slow and finish off properly
![Hang Loose :hangloose:](./images/smilies/action-smiley-035.gif)
