Page 5 of 6
Re: Fiat 126p - Aircooled 650cc 2 cylinder
Posted: Thu Jul 05, 2012 7:31 am
by eben
Got a video of the clutch action... nice to have a cover that you can remove to reveal the secrets...
Posted: Thu Jul 05, 2012 7:32 am
by eben
by eben
Crappy video with my phone but it gives you an idea of how the Reece-Fish operates.
Posted: Thu Jul 05, 2012 7:33 am
by eben
Working on a "rough" test manifold to try out the carb. There might be an issue clearing the ignition leads....
...& yes... I know the flanges are too thin.. I'm kind of limited to using a grinder, hacksaw, drill stand and grinding stones to make stuff but once this works I might make it more sturdy. ;D
I would need to support the carb anyway.
Posted: Thu Jul 05, 2012 7:35 am
by eben
Need to figure linkage, support and leads out...
Posted: Thu Jul 05, 2012 7:36 am
by eben
YAY! I didn't adjust anything yet... but it works niiccee.....
Remember this carb doesn't have any jets. Adjustments are a air bypass, throttle butterfly position and WOT enrichment screw...
What do you guys think?
Next thing is to make it permanent.
No flat-spots like with the 28IMB Weber.....
Posted: Thu Jul 05, 2012 8:33 am
by Retrobug
Looks cool! 8)
What are the plans for the air filter?
Hope it's something period looking! :hangloose:
Posted: Thu Jul 05, 2012 1:10 pm
by eben
It would have had a trumpet and pancake originally... don't know if that will fit...
Posted: Thu Jul 05, 2012 1:13 pm
by Ron&Gill
Ag, nee, foei, dit lyk alles dan so mooi, en dan? Dan jy weld nes ek! :lol:
Posted: Thu Jul 05, 2012 8:27 pm
by eben
Hahaha ja Ron maar ons is mos nie skaam nie...
Posted: Thu Jul 05, 2012 8:37 pm
Eben, have you had the fiat on a fuel analyser yet, is the fuel mixture correct through the full rev range??
That carb is more simpler then the Webers, but look and sound great,.
I think we should all go that way. it they correct. what is your fuel economy compared to the original carb.?
Posted: Thu Jul 05, 2012 10:53 pm
by eben
Hi, no no tuning yet. I will start the rough tuning this weekend and maybe use a colortune later. This Carb has an interesting tuning procedure.
Posted: Fri Jul 06, 2012 12:27 pm
eben wrote:Hi, no no tuning yet. I will start the rough tuning this weekend and maybe use a colortune later. This Carb has an interesting tuning procedure.
Interested to hear the result, and maybe post the tuning procedure, would be interesting.
Posted: Fri Jul 06, 2012 10:47 pm
by eben
It involves odd-sized allen keys, a ballpoint pen, running the engine at 2000rpm, adjusting the position of the butterfly on the shaft for max intake vacuum and running the engine at full throttle for peak power delivery. :)
Posted: Wed Nov 07, 2012 4:37 pm
by eben
Still have vacuum leaks...
