vader wrote:I dont have to come anywhere.... My proof lies in the DarkSide's stopping power....
Come for a drive in the DarkSide and the benefits will be self explanatory.
You cant compare the drums on a Beetle to the disk on a golf... The '67 beetle (840kg)is lighter than the golf (just under a ton). Of course they will have similar braking times.
A Brake booster is an enhanced master cylinder setup used to reduce the amount of pedal pressure needed for braking. It employs a booster set up to act with the master cylinder to give higher hydraulic pressure to the brakes and/or lower force applied on the brake pedal. The brake booster usually uses vacuum from the engine intake to boost the force applied by the pedal on to the master cylinder, or may employ an extra vacuum pump to enable it. Without the engine running the brake pedal feels very hard and ineffective on the braking capability.
Here is a challenge for you then.... Bring ANY beetle with drums and I will out brake them with the DarkSide over 10 or 20 stops from 100km/h. And then you'll have your proof!!!!
Maybe you should try some of my gas mixture it might remove that mental block your having.....
Sorry Vader, I said the topic is closed but please base you comments on facts and not opinion.
I just checked the weight of one of my
Citi Golfs, 847KG.
From your Copy and Paste (
http://en.wikipedia.org/wiki/Brake_booster ) there are two points I would like to point out to you.
1) A Brake booster is an enhanced master cylinder
and
2)Without the engine running the brake pedal feels very
Do you understand that with out the engine running, you have the same effect as not fitting a booster and as you correctly stated :"the brake pedal feels very hard and ineffective on the braking capability"
If there is some part of this that you dont understand, please come visit me.
In every day driving how many people make 10 > 20 emergency stops. In real life when a kid runs out in front of you car, you only get one chance.
Come ride with me and I will show you a new world of braking.
