Page 5 of 104
Posted: Fri Jul 03, 2009 10:43 pm
by 1972
i spent my day starting to attempt to move beetle into storage....
Posted: Sat Jul 04, 2009 3:08 pm
by Chris
Had to replace my lights as the old rubber ones broke from old age.
Posted: Sat Jul 04, 2009 3:47 pm
by Dutch_Diver
I cleaned MO!
Posted: Sat Jul 04, 2009 7:06 pm
by Tristram
I swore proffusely at mine today, stalled in traffic, freaking hot starting problem a pain in the proverbial ass. Thanks to two really drunk mechanics that stopped and helped us out.
Posted: Sat Jul 04, 2009 8:33 pm
by Blitzkrieg
Nice meeting you sean! You have a sweet beetle and seatcover!
Posted: Sat Jul 04, 2009 8:36 pm
by Chris
Blitzkrieg wrote:Nice meeting you sean! You have a sweet beetle and seatcover!
Were you the drunk mechanic??
Posted: Sat Jul 04, 2009 9:39 pm
by karmakoma
Started some light interior cosmetic work, see my thread:
http://www.aircooledvwsa.co.za/viewtopi ... 5&start=60
Posted: Sun Jul 05, 2009 9:23 am
by Tristram
(were you the drunk mechanic) he he no dropped in at blitz for a couple of bits and on the way home in boksburg my bug decided it wanted to chill and watch the aeroplanes. Nice meeting u too man got two nice toys there in the garage .
Posted: Sun Jul 05, 2009 8:22 pm
by Hloni
Gave her a lekker exterior wash b4 putting her into garage.
Noted that rims have size punched on them, 4J X 15. I know this has been adrsd, but not sure where 2 find thread, however, what is the ideal size & max SAFE size tyre 1 c an smack on this rim.
I also have set of widend Ghia rims, how do l work out which tyre width to smack?
Posted: Sun Jul 05, 2009 8:57 pm
by Dirk
Finally finished the front door panels for Christn. Now moving on to the rear.
Posted: Sun Jul 05, 2009 9:09 pm
by karmakoma
Started her up again, drove round the yard.
Took a little video of how easy the engine starts and posted it.
Took some more pics of the headliner to plan the restore.
Posted: Sun Jul 05, 2009 9:48 pm
by Blitzkrieg
Removed all the spiral plastic wrap from the wiring under the rear seat... Started modifying a late beetle steering column tube, have to cut off the bracket that mounts the tube to the dash and weld on a different position so that it's compatible to the type 3 dash...
Posted: Sun Jul 05, 2009 10:30 pm
by hitlers revenge
Removed, repaired and replced my buggy's fuse box. Washed and polished the'66.
Posted: Mon Jul 06, 2009 8:27 am
by Thumper
On Sunday 5th I replaced both tappet cover gaskets.
Replaced sparkplugs, condensor, points, oil.
Modified the the oil breather pipe, it was a bit kinked.
Replaced the brake light switch on the master cylinder.
Washed the engine with a degreaser.
wanted wash and wax the bug, but still had to mow the lawn....my dog had dissapeared into that jungle and had to find him. so...next weekend then.
Posted: Mon Jul 06, 2009 7:49 pm
by Tristram
Spent the last half hour sitting in the dark and cold, figuring why my bug cut out 4 times in peak hour traffic, whilst detailing the carb discovered that the choke spring wasnt connected, suspect it courtesy of a a certain carb rebuilding company when i had it overhauled. So opened it up reattached it positioned it to the choke marks. Maybe this will put pay to my hot starting problems.
