Late night Friends
- hitlers revenge
- Been thanked: 36 times
Re: Late night Friends
Missed you this time as I was playing with the Ford AGAIN!
Just had all the exhaust valves renewed and the heads serviced.
Now I have what looks like a leaking welsh plug.
Want to get this completed so as to start stripping the Fasty.
By the way my Exzema returned ( same time - new year)
Today I finally nailed the problem.
The bloody salt water swimming pool.
welsh plugs.... pfa... watercooled words
LOL
I had Christo come around in his big V8. Everything in that car that holds oil has a leak.
I was too busy to make a turn past your place too - except with a trailer which I hired on old paarl road.
Next time hopefully
LOL
Next time hopefully
bad luck on the skin.... not good.
Chlorine for you???
Chlorine for you???
- hitlers revenge
The salt is there to make chlorine. Gonna have to try without salt. Now all I can do is go lie in the bath in this heat.
Good to have you comment again Mr. HR
Need to see some pics of the Ford,
Also have the skin thing, but mine is from Hydraulic oil as well as brake fluid.
Use "Barrier Cream" before working now and when done, wash it off, works like a bomb
Will see you in George, not sure if Tony will be back by then, but would love to do a CT trip some time and meet up again.
Have a good day gents.
- hitlers revenge
Hoping to be in George. My daughter is only back at Varsity from the Monday after so we will probably make it a family run this year.
- hitlers revenge
Was worried about the Ford and LRP fuel. But have since changed to unleaded.
Which means petrol is freely available.
Last time in the Fasty we had to search for petrol.
Sorry, wont be back by George.
I'll get to the show again sometime, but my current rotation has me away Jan and Feb each year, which is why I missed 2015
If you have the heads off in March, bring them around and I'll cut a seat quickly to see if it is unleaded ready. They usually are.hitlers revenge wrote:Was worried about the Ford and LRP fuel. But have since changed to unleaded.
Come on Dave, you can join the crew outside...hitlers revenge wrote:The salt is there to make chlorine. Gonna have to try without salt. Now all I can do is go lie in the bath in this heat.
Sorry to hear Tony, but will set a trip when you in CT later.
Dave, why are you not using LRP in the Fasty, it will run perfect, and not get hot.
Heads are fine for LRP.
Why are you guys still awake???
The heat is the thing, and am sitting in undies when all other are sleeping,
Shock factor ...you know....
Are you on watch, or just off duty, ?
just knocked off.
Its 1800 here...
Its 1800 here...
I am always on watch... joy of being Chief
