MrT wrote:...
My main consideration was the saggying rear end and the fact that I have changed the rims to 14" and will be fitting 195 70's.
The Ass down, has always been a way of life for the type 3, I have a type 4 in the back which carrys near 50 Kg more then the type 3 motor, all I did was set the back up two splines, still has the ass down stance, but the ride is excelent.
Just beware that you do not over rev the engine with the 14 " wheels, you will overheat the type 3 motor with ease.
Reason I fitted the type 4 !(sucks more air, better fan). As you have a Notch, with boot vents, you will not have the problems that the Variant and Fastback have of the narrowing back body, which gives a negative air pressure over the fins, at high speed, always had
with my fasty overheating, till I fitted a fin end scoop.
(now wait for comments to fly)
