Page 4 of 15
Re: MY 1964 VW Type 3 Notch
Posted: Sun Sep 23, 2012 10:56 pm
by Riekert
Posted: Sun Sep 23, 2012 11:00 pm
by Riekert
Posted: Sun Sep 23, 2012 11:03 pm
by Riekert
Posted: Sun Sep 23, 2012 11:11 pm
by Riekert
So jumped on the pics...
Now here's what I'm up to..
Removed the motor for a clean, checking plugs and oildrain. Main reason though is the flywheel as you would've seen... will be replacing the flywheel and then put everything back together again.
So lots to do still!
But getting there slowly!:grin:
Laters!
Posted: Tue Sep 25, 2012 2:13 pm
by calooker
Something is not right with your tranny clutch setup??? :zhelp: looking at the pics ....... :puterwork:
You have a early tranny (unsupported thrust bearing) and a later clutch plate without a collar, you need a early pressure plate to mate things up correctly, did you drive the car with the current setup :shock: ??? I think NOT. :lol:
Posted: Tue Sep 25, 2012 2:24 pm
by Blitzkrieg
What calooker said. But you can also convert the gearbox to the later setup - I have one of those conversion sleeves available if you want to go that route...
Posted: Tue Sep 25, 2012 2:29 pm
by calooker
Blitzkrieg wrote:What calooker said. But you can also convert the gearbox to the later setup - I have one of those conversion sleeves available if you want to go that route...
Will also need to change the fork and thrust bearing, changing the fork with tranny fitted is a real pain as the return spring needs 3 hands and a fancy language to fit in place. Much easier just to change the pressure plate.
Posted: Tue Sep 25, 2012 8:08 pm
by Riekert
Ah... ok did not know that! Thanx for the info! Anyone got a pressure plate that'll fit?
Will take some better pics of the gearbox tomorrow.
Posted: Sat Nov 24, 2012 3:50 pm
by Riekert
Some updates.
Got motor back with new flywheel. Brakes more or less sorted and carpets back in. Going good...
Pics...
Posted: Sat Nov 24, 2012 4:08 pm
by Bugger
Looking at that Flywheel it might be possible that you still got a 6V starter in the Tranny and the reason why the flywheel was abused like that as you can see the bigger teeth marks in the flywheel
Have a look at the starter take it out and check on the side if you can see any markings 6V or 12V
If 6V you will need to change the starter to 12V and I do have conversion bushes to fit in the tranny to accomodate the 12V starter as it have a much smaller shaft size as a 6V
If you need help or anything give mee a bell
082 600 8663 Pierre
even if it is on a sat or Sunday
Posted: Sat Nov 24, 2012 10:55 pm
by Riekert
Thanx will gave a look at that. And thanx I will possibly give you a shout
Posted: Sun Nov 25, 2012 3:21 pm
by Riekert
some pics. Got my "new" lenses from Mr T.
:grin:
Posted: Sun Nov 25, 2012 3:31 pm
by Riekert
So which light looks better?
Posted: Sun Nov 25, 2012 3:39 pm
Very much a personal taste..... :wink:
Me, myself and I, all 3 of us, like the old type, but, that is because we know it like that.
With both on, the new shape ones are also nice.
Sorry for sitting on the fence, but after all, your car, you must be happy with it.
Its a type 3, so we love it anyway..... :D
Posted: Sun Nov 25, 2012 6:09 pm
by Riekert
Haha thanx! Also just to check the older one is the flatter one hey? And its true. Will put the flat/old ones on as they kinda suite the car better for me :grin:
