Split bus adjustable Straight Axle Kits finally done
herbie123
What model do you have?: a few
Been thanked: 4 times
Re: Split bus Straight Axle Kit and Bug finaly enter product
Post by herbie123 »
HI Pierre
Can you let me know when you will have these kits ready , please reminder my set without the "cut out'
Thank you
kts customs
What model do you have?: 1971
Facebook: yes
Post by kts customs »
hi im also still waiting may be next xmas :)
kts customs wrote:hi im also still waiting may be next xmas :)
:lol: :lol: :lol: :lol: :lol: :drunks: :drunks: :drunks: Lets Drink to that
Guys If I had control over the People and machine shops then these things would have been done Long time ago already
I was stuffed around so badly with everyone but the Light is at the end of the Tunnel
I finally got the Bushes from the Guys that supplied them and then I have cut the Whole Steel Plate I had in to Straight Axle kits and 2 sets of Beetle Adjustable kits
I got the Kits back from the Guys that did the Welding for me but was just to late to get them Splined
So Now as soon as the Guys that will be doing the Splining open I will Drop all the parts off at them and hopefully end of Jan all will be done
Herb I changed all of the Kits to with out the cut out as it made everything just easier and also moved the adjusting parts closer to the splined bush to give much more clearance for wider wheels
herbie123
Post by herbie123 »
Hi Pierre
That sounds great will wait for the end of January
Have a good New Year ,
Andreas
kts customs
Facebook: yes
thanks so much dude for all the effort
herbie123 wrote:Hi Pierre
Andreas
Thanks Andreas the Same to all you ACVW junkies
Hy Kevy its not Effort at all it is a Challenge I want to see through and just to Prove again We here in SA can do it :hangloose:
Bugger wrote:Hi Guys
As they are Adjustable one of the major advantages is that when you jack the back up the wheel rim comes down completely out of the fender well so changing tyres will be a breeze as I know of 2 fellow members that have a real struggle when they need to replace tyres
I have a dics kit on the 15 window and 30mm spacer bringing the wheel more out and you can even fit a wider spacer for a nice wide rim
and there is about another 3 finger gap between the outer of the rim and the inner of the fender
[/color]
Ok So there are the First 3 sets Ready for Collection and I stand by my original costing post as I recon it is by far alot cheaper than to import a adjustable Split bus set from over the water
Kevvy has Booked a set
Andreas has Booked a set
Then there are 1 set available who needs a name
I have only done 3 sets after the First R&D set as I need to firs sell these sets to get finances in to make a few more sets
Re: Split bus adjustable Straight Axle Kits finally done
They are Done :hangloose: :hangloose:
Quite funny not one set sold yet where is everyone that haunted me to make them ?
kts customs
Facebook: yes
Hi will coll mine this week my bus is almost done at paint shop
If u coming to pta pl bring it along
kts customs
Facebook: yes
collected
Had to stirr a bit :lol: and now they are flying
1 set left of the first 5 made will make some more
Thought I would load some pics of a bus with a set of my Straight axle kit on and with front beam adjusters
Burnthosetyres
What model do you have?: 64
Post by Burnthosetyres »
Pierre how many straight axle conversion kits have been sold/ fitted to forum members busses? All good?
KTS Customs Kevvies bus
Mike 15 window fleetline
Peter v Dyke
Another mate of mine in Pieters burg
I had alot of interested parties some I might have missed as it took a bit longer as anticipated to R&D And do it right the first time But I wanted to do it
Local and be able to supply instead of waiting for ever from the UK and shipping is expensive for the plates and 2 axle tubes as it is Quite heavy together
But I can assure you they are the Right material etc and work better than the imported ones as these can lock where you set them with out using lock tite
as the imported kit only have a Grub screw to lock I maved my Pivit Point closer to the Splines which gives you more room for a wider rim
and the Steel Blocks ate much thickker to accomodate the turning of the Locking nut on the Adjustable bolt
