Page 4 of 14
Re: Mild 1600TP Turbo engine
Posted: Fri Jul 22, 2011 9:19 am
by Bratjie
Ok so the turbo build is definately on the back burner for now, I have 4 guys waiting on recon engines and I had to part with my turbo project engine to help another fellow out. That really suck's
, but I'm sure to be on track soon
Posted: Fri Jul 22, 2011 10:32 am
by riaanj
4agedub wrote:We've done a couple of 1600 tp turbo beetles before. The best turbo so far for that application is from a 1.9tdi vw.
Just a question, if that works, will a turbo from a Hilux 3.0l KZ-Te work on a 2.0l aircooled combi motor?
'Cause as luck would have it I have a Hilux turbo and a 2.0l combi motor here and have been toying with the idea of trying a turbo conversion..
Posted: Tue Aug 23, 2011 8:05 am
by Bratjie
Back on track again!!!
So I've spent the last few weeks just prepping the car, fixing nick's and scratches, tried my hand in fixing the front fibre spoiler and it came out good, finished the spray job last night and waiting a few day's before I can flat and polish. Casing has been done and just popped it in the acid bath to clean properly, heads have been ported going back to engineering to fit new guides. Still waiting on the Empi 1.25:1 rocker set ordered, should be here by weekend. Front disc's fitted and castor shims too, so she should handle a little better. Sway bar is next on the list,
Need to find someone close to balance crank, flywheel, rods & pistons, and as the engineering shop have "misplaced"
my stock valves I might as well look for a set of stainless ones.
Just wish I could take a few days leave, it's just taking too damn long to get everything done
Posted: Tue Aug 23, 2011 10:14 am
by justin
Bratjie wrote:Need to find someone close to balance crank, flywheel, rods & pistons, and as the engineering shop have "misplaced"
I have had good work done by Smiths Auto in Silverton...
Posted: Tue Aug 23, 2011 11:28 am
by Bratjie
Do they do balancing, how much approx, my current engineer will assemble heads & so forth but do not do any balancing?
Posted: Tue Aug 23, 2011 1:33 pm
by Bratjie
justin wrote:Bratjie wrote:Need to find someone close to balance crank, flywheel, rods & pistons, and as the engineering shop have "misplaced"
They can do it for ........ R 2100.00
Posted: Tue Aug 23, 2011 3:37 pm
by splitfan
I have always used Dynamic in Edenvale , never had any issues just had a waterpumper bottom end ballanced worked out to less than R700-00 , rods,pistons,cranc,flywheel,pullys and clutch ect.
Posted: Tue Aug 23, 2011 4:33 pm
by Bratjie
splitfan wrote:I have always used Dynamic in Edenvale , never had any issues just had a waterpumper bottom end ballanced worked out to less than R700-00 , rods,pistons,cranc,flywheel,pullys and clutch ect.
Wow I will definately give them a try, thx's,
Posted: Tue Aug 30, 2011 11:51 am
by Bratjie
Just an update,
Sending the rotating assembly to JHB for balancing on Friday, 1.25:1 rockerset will be here tomorrow, heads almost done & ready for assembly,
Picking up a coil driver & electr ign coil over the weekend for the electr dizzy. Still need A/F ratio meter, manual boost controller, BOV, 30mm oilpump, Dellorto jetting, and the odd fuel pipes and wiring etc,etc, almost there whew
looks like I'm working backwards but funny, progress is made
With all this put together approx cost will be around 23K incl front disc brakes ( no g/box or susp mods included, no upgraded clutch assy, ) Wow, I've heard them say you can't properly budget for a build like this before and it's true.It's when you're done that you can get a clear picture
, anyway I'm sure it wont end there and the fun will be worth the while
Posted: Fri Sep 02, 2011 9:24 am
by Bratjie
Excitement, excitement
, 1.25:1 Rocker set arrived and sitting on the shelf smiling, now I'm just waiting for a Sleeve set a good friend of mine has given to me and it all goes for balancing, can't wait to begin assembly
Posted: Fri Sep 02, 2011 12:45 pm
by calooker
I see it this way, whatever the initial budget was, DOUBLE it, it will be more realistic.
Posted: Fri Sep 02, 2011 1:12 pm
by Bratjie
You are dead right, I never thought I'd end up here
Posted: Fri Sep 02, 2011 3:36 pm
Bratjie wrote:You are dead right, I never thought I'd end up here
you are not the first person to realise this....
Posted: Fri Sep 09, 2011 2:22 pm
by Bratjie
Bit of an update, I received the heads back today, all shiny and good looking with new guides and shiny new valves, see the difference in spring lengths
Ported and polished by Wena (1st ever) but it came out very good, fitted the high rev valve springs and mocked up those schweet 1.25:1 Empi rocker set
next are the moly pushrods and cam followers.
Now she's gonna rev like a mad woman
Posted: Fri Sep 09, 2011 6:54 pm
by Bugger
Yes it all ads up so Quick that if you blink your Eyes then you have spend R8K just on machining on a Type 1 motor ask me as I just got the call from the Engineers that Elvis the 66 Squareback machining is done
