Just an update,
Sending the rotating assembly to JHB for balancing on Friday, 1.25:1 rockerset will be here tomorrow, heads almost done & ready for assembly,
Picking up a coil driver & electr ign coil over the weekend for the electr dizzy. Still need A/F ratio meter, manual boost controller, BOV, 30mm oilpump, Dellorto jetting, and the odd fuel pipes and wiring etc,etc, almost there whew
looks like I'm working backwards but funny, progress is made
With all this put together approx cost will be around 23K incl front disc brakes ( no g/box or susp mods included, no upgraded clutch assy, ) Wow, I've heard them say you can't properly budget for a build like this before and it's true.It's when you're done that you can get a clear picture
, anyway I'm sure it wont end there and the fun will be worth the while
