Projekt ohne namen
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Re: Projekt ohne namen
Post by buggyfan »
Easy,remove bonnet,put two 50kg bags next to each other on top of petroltank,replace bonnet and Bobs your uncle .that nose is going nowhere when a truck passes you by!
Hloni
Has thanked: 14 times
Post by Hloni »
Serias? sandbags is all l need?
3011
buggyfan
Long Block
Post by buggyfan »
No,i mean to say bags of cement!
Hloni
Post by Hloni »
The steering box:
What type of oil do I top it up with, and how much?
3011
Hloni
Post by Hloni »
Hloni wrote:The steering box:
:zhelp:
3011
I think you can put grease in, but I am not sure. Dont quote me on it.
Do not put grease in, as it will get hard, not cover moving parts, and destroy the box.
IF your box is OK, fill with SAE 90,
IF box is "Dodgie" fill with "Wins" or Bardel, something thick, then it will take up the play, and drive like a new box.
makes sense
Hloni
Post by Hloni »
Do I just gooi in oil through the 2 wholes on top until it overflows or how does it all work? :oops:
3011
Hloni wrote:Do I just gooi in oil through the 2 wholes on top until it overflows or how does it all work? :oops:
YAA!, you gest froose it in, till it does not gooos in anymeer.
:lol: :lol: :lol:
Test your old oil 1st, if dirty, try and get as much out as possible, then fill to top.
If it will drain, let it all drain out, and refill.
Been thanked: 21 times
Post by Ron&Gill »
buggyfan wrote:Easy,remove bonnet,put two 50kg bags next to each other on top of petroltank,replace bonnet and Bobs your uncle .that nose is going nowhere when a truck passes you by!
Bollocks, sorry Buggyfan :D , but bollocks. You do not need 100kg of shit in the front. A beach buggy is perfectly stable, at high speeds even, when set up correctly. Steering dampener in good working order, K&L pins good, alignment good, shock new, and tyre pressures correct, i.e. 0.5 bar in front and 0.8 bar at the back.
I have driven my buggy at speeds well over 160km/h on many long trips (>2000km at a time) and my buggy is stable. Adding 100kg for no good reason just slows your buggy's acceleration, increases fuel consumption and lengthens braking distance.
buggyfan
Long Block
Post by buggyfan »
Thanks Ron,ive been waiting patiently for someone to call Bullshit on that one!
@Hloni,you drive the hiways and biways of kzn on a daily basis.
so im sure you would have seen plenty buggys lying upside down next to the road after being passed by trucks if that was to happen
buggyfan
Long Block
Post by buggyfan »
Post by Ron&Gill »
Perudo!!
Hloni
Post by Hloni »
BF, funny thing is there not many on the open road hey. Stax of Chatsworth & lsipingo guys use them as "fishing cabs", so by the sand one checks them out. Driving up the N3 between Pmb and Alberton, l'd be fortunate to see an acvw on the road. A few British classics in English Midlands, but that's about that.
R&G, do l have to lower the front to get the desired effect drive or replacing/adjusting what you highlighted would suffice? :drunks:
3011
