Been fitting the side shafts and the decals to the doors.
FYI, should you be fitting "once off" CV joints and side shafts for the 1st time, do a trail run, with out grease,
You land up a lot cleaner THAT WAY..........
Been a time since the last update, so here goes.
Been busy with family life, death, visits,and other issues, but managed to get a few hours in.
Had to do some drilling and tapping on the front brake calipers as the threads did not look too good, also fitted new disks and got the wheels painted.
Sure you would want to see the wheels, as they would look on the truck.... but here goes ...
Before hub cap ....
After hub cap ...
So now for the proof that Herman has fitted a Type 4 2Lt Kombi motor with a Type 4 gearbox to the front of the MeFusco, landing up with VW aircooled Front Wheel Drive.
So here you go guys, CV joints, disk brakes, side shafts, Gearbox, McPherson struts, all in place and near ready to go.
Thanks for looking,
Till next time
Before hub cap ....
After hub cap ...
Thanks for looking,
Till next time
- AlanH
- Has thanked: 126 times
- Been thanked: 86 times
Very cool, I'm just wondering how you are going to register her?
Wanted parts:
Left sunvisor
Sink faucet
Left sunvisor
Sink faucet
Thanks Alan,AlanH wrote: Thu Dec 24, 2020 6:59 pm Very cool, I'm just wondering how you are going to register her?
We will see, maybe as a "built-up", or as a "Kit car"
The important part is to get him done.
Sorry guys, Not much to report.
We are busy with the wiring and fitting the electrical equipment, but its a bit slow.
Got a VW SP harness, but its so bad and modified, I have to strip it and use individual wires to make my own harness
Brake lines have to wait till after the 4th Jan, as my brake guy is closed, so busy with other things.
Will be keeping you up dated
So yes we still on the electrical.
Fitted the dash and gauges, as most of the donor car was trashed, we need to make up parts or repair fitting or bolt points.
My brake guys making up my complete pipe system, should have that in the next day or two.
Still looking for the head light dim / bright and flash high beam relay. Looks to be a national shortage.
So till next time , Keep safe
- Camshaft
- Been thanked: 107 times
Stoffel,....picturing this vehicle kicking up dust in the desert,........"stoffel"
Good point, Maybe he should have a name and surname..Haans wrote: Wed Jan 06, 2021 8:24 am Stoffel,....picturing this vehicle kicking up dust in the desert,........"stoffel"
Stoffel MeFusco
Haans wrote: Wed Jan 06, 2021 8:13 am So,....when is starting date for "Stoffel"
Not rushing him anymore due to George and other shows being postponed.
And also not feeling like taking on a new project during this covit times.....![]()
Old Dutch and Brazilian with a small hint of Scottish.Haans wrote: Fri Jan 08, 2021 6:44 pm I like ,......Stoffel MeFusco,....from german and mexican decent ??
- Has thanked: 45 times
- Been thanked: 208 times
Scottish... Would that be the Vauxhall part?
Correct ...but truth be told ...
He has Scottish leader front, German Power house central management, and a cute French back end.
(Vauxhall) (VW) (Renault)
(the old Dutch is the old Toppie, and the Brazilian only in name)
