My 356. Now sold.
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
Re: AP 356 Speedster Replica - Rebuild.
Thanks, a
It's always been red, just been resprayed a fresh new coat.
Oh, and it's def not a She.
FINALLY, managed to cover the Dashboard "brow".. Horrible thing to work on.
- acpaterson
Another big, awkward, but important job done. All the new lights all the way round are wired back up and 100%. Upside down under engine bay for a few hours isn't fun. Arms are knackered..
So, finally ready to sit in the drivers side of the car and attempt to clean up, straighten out what I have as a wiring harness. Then get gauges hooked up and hopefully all work ok.Need to get the Seats back to the Upholsterer. Was very close to cutting mine down to "look" original, but decided for what.. This isn't an Original, and I like to small headrests for both Safety and Comfort. Then still trying to tie down a deal to get a carpet guy to do the carpets..
yip, safety first.... glad you used your head
- acpaterson
Sunday, did a few small fixups.. Made Silicone seals around the base of the Windscreen frame as mine has a gap round the base. Should help for a water-proofing inside as well.
Then attached the wiring.. Wasn't too bad actually. Glad to find out the Tach works 100%, so the only un-known right now are the fuel gauge and the Speedo, but both are relatively easy fixes.
Cars starting to look EXACTLY what I wanted it to look like.
- acpaterson
So, in my attempt to put this dash together as original and "period" as I could, I decided to use Ivory(Resin) Knobs. Well that's all fine and dandy until you get to the Hazard Switch. Now this animal has a straight forward threaded shaft with a small bulb in it. I just figure, if I cut a Bolt with enough thread, I can simply screw it into the Hazard Switch, (which it can), and on the other end, simply screw on one of my tapped knobs...
About 8 fuses later, I realize there's a problem somewhere.. I semi-burn out the Hazard switch, and go buy another off junkads. Same
So I've dremeled a recess cavity into the knob, and resin glued the original shaft with the black surrounding part cut off onto the Knob.. Will still look period, and doesn't short the fuse out..
Ho hum..
- Has thanked: 36 times
- Been thanked: 50 times
Progress.....I must admit the 912 gauges really look the part.
Everyday's a school day.
- acpaterson
Yep.
PS. Tach works 100%, glad about that.. Need to see how the Speedo works, and hopefully the fuel gauge etc.. Struggling with the Idiot lights.
glad to hear that the tach works...........does your speedo cable fit?
- acpaterson
yup, fitting should be the same, mine is too damn short hence it being on the other side........
- Mustang Sally
- What model do you have?: Porsche 356 replica
- Has thanked: 7 times
- Been thanked: 2 times
Hey Alan, you really need to rethink this He/She issue.
Your car is so damn sexy that it is rather disconcerting thinking of it as "He"!
- Speedy356
- What model do you have?: Porsche 356 (Rep).
- Location: Dinokeng Nature Reserve, Pretoria (Dont know where the hell "Tswane" is!).
I agree. Could call it a he if it was a forklift.Mustang Sally wrote:Hey Alan, you really need to rethink this He/She issue.
Your car is so damn sexy that it is rather disconcerting thinking of it as "He"!![]()
Yes it is a replica, but it is mine!
Remember......Drive it like you stole it!
Beware of stupid people......Especially when they congregate in large groups!
I suffer from the same problem
- acpaterson
rotf..
Naa, It just rubs me the wrong way how everyone references their cars or bikes as a "she".. FFS.. it's not a SEX, its a bloody car.
conversely, that doesnt make it a "he" either...
I suppose its an "it" or a "thing"
check vir die ding....
