Page 22 of 55
Re: My type 1 turbo project
Posted: Sat Mar 08, 2008 11:03 pm
by 2BugMe
Well done 4Age,
You did well to get her going man...and at least nothing broke or burned hey :wink:
There goes more school fees with the replacement parts...you must be a genius to figure these things out man...
Happy miles...and keep us posted...
:hangloose:
Posted: Tue Mar 25, 2008 11:15 pm
any more news???
Posted: Thu Apr 10, 2008 12:45 pm
by 4agedub
Hi guys
I have not been on the forum for a while now, things have just been a bit hectic here at work.
Some news.
I started mapping my beetle on tuesday night. Went up to 3500rpm, 0.4bar boost and making 70kw on the wheels so far. Stopped there so I can check all the valve clearances again. Engine temperatures went up to about 68'c and oil pressure stays good.
So I'm very happy. This weekend I will adjust the valves and reset the clearances to 0 again (cromoly pushrods) So next week we'll map her to 6500rpm and 0.8 bar boost. :)
Posted: Thu Apr 10, 2008 12:54 pm
by Blitzkrieg
Nice, thanks for the update
Quick question, does Gotech sell 60-2 trigger wheels?Or would I have to modify a Bosch Part from a Mercedes Benz or something similar?
Posted: Thu Apr 10, 2008 12:58 pm
by 4agedub
We make trigger wheels. The one on my beetle was a once off wheel, but we do keep bigger one's in stock.
Posted: Sun May 11, 2008 10:05 pm
by 4agedub
A small update.
Got my semi's fitted.
Front's running dunlop semi's 195 and back running bf goodrich drag radials 205
Posted: Sun May 11, 2008 10:06 pm
by 4agedub
Posted: Sun May 11, 2008 10:07 pm
by 4agedub
by 4agedub
Posted: Sun May 11, 2008 10:09 pm
by 4agedub
The crank angle sensor is now mounted as well.
Posted: Sun May 11, 2008 10:10 pm
by 4agedub
Posted: Sun May 11, 2008 10:12 pm
by 4agedub
The turbo with air cleaner mounted. Firewall dummy installed, now just need to be painted.
Posted: Sun May 11, 2008 10:13 pm
by 4agedub
Posted: Sun May 11, 2008 10:15 pm
by 4agedub
The firewall from inside the cabin.
Posted: Sun May 11, 2008 10:18 pm
by 4agedub
Now this part I'm very proud of... quick release rear window. I modified the read window rubbers to simply slide in and fastened the window with Dzus fastners for quick release.
So to get to the engine bay simply remove the rear window and open the firewall.
