2BugMe
Posts: 265 Joined: Fri Sep 21, 2007 11:00 pm
Been thanked: 2 times
Post
by 2BugMe » Sat Mar 08, 2008 11:03 pm
Well done 4Age,
You did well to get her going man...and at least nothing broke or burned hey
There goes more school fees with the replacement parts...you must be a genius to figure these things out man...
Happy miles...and keep us posted...
Posts: 15009 Joined: Wed Sep 14, 2005 8:33 am
Has thanked: 192 times
Been thanked: 488 times
Post
by Tony Z » Tue Mar 25, 2008 11:15 pm
any more news???
4agedub
Posts: 1613 Joined: Mon Sep 19, 2005 11:36 am
Has thanked: 4 times
Been thanked: 13 times
Post
by 4agedub » Thu Apr 10, 2008 12:45 pm
Hi guys
I have not been on the forum for a while now, things have just been a bit hectic here at work.
Some news.
I started mapping my beetle on tuesday night. Went up to 3500rpm, 0.4bar boost and making 70kw on the wheels so far. Stopped there so I can check all the valve clearances again. Engine temperatures went up to about 68'c and oil pressure stays good.
So I'm very happy. This weekend I will adjust the valves and reset the clearances to 0 again (cromoly pushrods) So next week we'll map her to 6500rpm and 0.8 bar boost.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
Posts: 10784 Joined: Wed Mar 07, 2007 10:41 am
Has thanked: 91 times
Been thanked: 44 times
Post
by Blitzkrieg » Thu Apr 10, 2008 12:54 pm
Nice, thanks for the update
Quick question, does Gotech sell 60-2 trigger wheels?Or would I have to modify a Bosch Part from a Mercedes Benz or something similar?
4agedub
Post
by 4agedub » Thu Apr 10, 2008 12:58 pm
We make trigger wheels. The one on my beetle was a once off wheel, but we do keep bigger one's in stock.
4agedub
Post
by 4agedub » Sun May 11, 2008 10:05 pm
A small update.
Got my semi's fitted.
Front's running dunlop semi's 195 and back running bf goodrich drag radials 205
4agedub
Post
by 4agedub » Sun May 11, 2008 10:06 pm
4agedub
Post
by 4agedub » Sun May 11, 2008 10:07 pm
4agedub
Post
4agedub
Post
by 4agedub » Sun May 11, 2008 10:09 pm
The crank angle sensor is now mounted as well.
4agedub
Post
by 4agedub » Sun May 11, 2008 10:10 pm
4agedub
Post
by 4agedub » Sun May 11, 2008 10:12 pm
The turbo with air cleaner mounted. Firewall dummy installed, now just need to be painted.
4agedub
Post
by 4agedub » Sun May 11, 2008 10:13 pm
4agedub
Post
by 4agedub » Sun May 11, 2008 10:15 pm
The firewall from inside the cabin.
4agedub
Post
by 4agedub » Sun May 11, 2008 10:18 pm
Now this part I'm very proud of... quick release rear window. I modified the read window rubbers to simply slide in and fastened the window with Dzus fastners for quick release.
So to get to the engine bay simply remove the rear window and open the firewall.
