69 squareback
- Been thanked: 98 times
Re: 69 squareback
I use Brake pipe or old beetle pushrods (cut ends off) to hide the threads, looks pro.
Re: 69 squareback
Wow JC, that looks stunning.
For someone who wasnt going to do much, I think you did pretty well...
- What model do you have?: 69,75split,75,79scab
- Has thanked: 85 times
- Been thanked: 16 times
Re: 69 squareback
So after a lot of carpet washing and washing and vinyl washing and washing and and and ,the interior looks all new
Rostyles ready for collection on Tuesday
Engine doing its carb setup and run in on Monday
So all and all it looks good for a drive on the weekend
Will post some pic`s tomorrow
61 Beetle aka klapperkiste
68 Squareback viewtopic.php?f=23&t=34408
69 Kombi
72 Crew cab viewtopic.php?f=23&t=32846&hilit=1972+custom
75 Fleetline panel viewtopic.php?f=23&t=32485&p=309053#p309053
79 Single cab
69 Kombi
79 Single cab
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
Re: 69 squareback
wow that motor looks bevok JC !!!! Did you come right with that missing air cleaner item ?
Re: 69 squareback
maybe we can go for a cruise somewhere early Saturday morning? My place to tableview for coffee?
Re: 69 squareback
Thanks Paul i did indeed come right
Tony we can do it man ,maybe a small run for the fun
will let you know if she passes road worthy , need my disk
69 Kombi
79 Single cab
69 Kombi
79 Single cab
Re: 69 squareback
69 Kombi
79 Single cab
69 Kombi
79 Single cab
Re: 69 squareback
I would like to know if anybody has a type 3 original exhaust (as a sample ,cape town area) ,I want to make up one as close to original as possible
For now i have modified a beetle silencer to fit the motor, had a nice old one laying around
Paul how is the exhaust on your squareback?
69 Kombi
79 Single cab
69 Kombi
79 Single cab
Re: 69 squareback
it seems my post didnt go through
JC, your engine isnt exactly stock anymore. Fitting a stock exhaust will likely limit your power quite a bit and possibly cause overheating. Either way, you will end up with a result you are not happy with and you should have rather stuck with a stock 1600
- jolas
Re: 69 squareback
Those rims look lekker man,
Sean recently used my Squareback to take measurements and make a sample of the silencer. I'm not sure if it is commercially available yet from the fitment centres they supply, but I'm sure he will reply here.
I'm still running with the sample and its all good
Re: 69 squareback
Thanks Paul ,check your whatsapp
I want to use the original exhaust to custom make one specific for my engine and Z Heads and more secret parts from Tony`s LAB
but still keep it looking original
69 Kombi
79 Single cab
69 Kombi
79 Single cab
Re: 69 squareback
69 Kombi
79 Single cab
69 Kombi
79 Single cab
- Has thanked: 45 times
- Been thanked: 208 times
Re: 69 squareback
Thats good news. Looks nice.
- beetlepower
- Twin Port
- Has thanked: 3 times
- Been thanked: 28 times
Re: 69 squareback
Do you have the pic of those clips? If the same as for middle, beltline, beading then Wurth or Goldwagen will have as they the same as Citi Golf
0828378801
@reubenvn on twitter
0828378801
