Page 3 of 122
Posted: Sat Mar 23, 2013 3:01 pm
by chrisradioman
Posted: Sat Mar 23, 2013 3:02 pm
by chrisradioman
by chrisradioman
The rest of the pics, my computer is real slow at the mo. so I'm struggling keeping up to date my new one comes tomorrow so look out then.
Posted: Sat Mar 23, 2013 3:03 pm
by chrisradioman
by chrisradioman
A nice chap called Suart called in to see me for a chat & I ended up going down his lock up to see his Beach Buggy, it was actually in a James Bond film in 1985 & the good news is that he plans on restoreing it to how it was then.
Went out down the Mumbles with My M8's Kevin, Clare & kids & Ali, Sue & kids. stoped first at Knab rock.
Posted: Sat Mar 23, 2013 3:04 pm
by chrisradioman
Katy decided to climb the kids playground:-
Then Kevin did:-
Spotted this old Splitty in Mumbles:-
& this old Volvo estate:-
3 of us Lined up out side the chippy:-
Even got a couple of pics in the chippy:-
by chrisradioman
Car park in Langland Bay:-
Posted: Sat Mar 23, 2013 3:05 pm
by chrisradioman
Spent yesterday afternoon playing with my lights, I removed the USA spec General Electric sealed beam units & disconected the grey wire from the front indicators (this is the side light feed) pushed this wire into the headlight bowl through the standard grommet kept the original spade so I didn't have to modify the wiring. I wouldn't recomend breaking any cables that are outside the vehicle so I ran a new earth cable put a ring on one end & secured it to the headlight bowl on the inside ot the bus to the location already used. pushed the cable through the grommet & fitted a size 2 red spade, used a brown wire to be consistant with the VW colours. Notice the UK spec indicator it has a twin fillament lamp & a small sidelight lamp so three separate light sources as opposed to the UK's one.
Fitted a pair of H4 lamps to the new Hella units I picked up & the side light bulb holders I salvaged from Chug Chug.
Connected them all up & now they are UK road legal. You'll notice that the UK Hella units glass is flat where as the USA versions are curved.
Posted: Sat Mar 23, 2013 4:44 pm
by buggyfan
welcome to ACVWSA,thanks for sharing your amazing buds with us :drunks: :drunks: :drunks:
please post more pics of the engine side of your bay aswell as tell us the sad story of the burnt bay in the background of one of your 1st pics
Posted: Sat Mar 23, 2013 8:42 pm
by Warwick-Lowlight
Thats a Ripper :hangloose: -thanks for sharing
Dig the 007
Posted: Sun Mar 24, 2013 8:36 pm
by riaanj
WOW, that's a nice bus!!! :flash:
Posted: Sun Mar 24, 2013 11:57 pm
by chrisradioman
buggyfan wrote:welcome to ACVWSA,thanks for sharing your amazing buds with us :drunks: :drunks: :drunks:
please post more pics of the engine side of your bay as well as tell us the sad story of the burnt bay in the background of one of your 1st pics
Thanks pal, I've got hundreds more pics to come & plenty of the engine, stay tuned to see more. I'll post a link up about the burned bay in the background, it was all very sad, that bus was the famous Chug Chug. :(
Posted: Sun Mar 24, 2013 11:58 pm
by chrisradioman
Decided to sort out the Flashers while I was playing the USA lights only flash when the lights are on where as the UK ones flash with them on or off. I removed the standard relay which as it happened was a 5 pin anyway fitted a size 3 red spade & red wire to the terminal 30 opened up the terminall location on the fuse box & refitted my new 5 pin relay. I connected this to a permanant live so now I can flash the headlights with the lights & ignition off (they just stay on untill you let go of the stalk) they also flash on & latch when the lights are on (drop off when you flash again). I may alter this so it only works with the ignition on I haven't decided.
Posted: Mon Mar 25, 2013 12:00 am
by chrisradioman
Got the Westy tow bar that was on Chug Chug off before he was scrapped. Had to weld the tag for the electrics back on because it snapped when I straightened it. My M8 Dean got it picked up shot blasted phospher coated & white powder coated for me. & now it looks the dogs bollox. The black marks are from where I trial fitted it. It won't fit properly because the Previous owner fitted J-tubes instead of the heat exchangers & this makes the exhust sit higher, when I get heat exchangers back on I'll fit it then & wire it in then I can tow my new Beetle trailer:-
Posted: Mon Mar 25, 2013 12:01 am
by chrisradioman
Got my new Propex heater yesterday, looking forward to fitting this I'll post full details when I do:-
Wired up & fitted my fresh air fan & it works so happy days, I also got my fridge working off the leasure battery, not sussed out the tap yet though, the split charging system isn't working its been wired wrong & I'll need to sort it.
Pics of batteries both will be changed soon:-
Going to fit this next my reversing alarm:-
Checked my back lights & I had a reversing light out so sorted it, happy to report my back lights are as new if not new & are Hella:-
