Page 3 of 3
Re: Projek '63
Posted: Thu May 16, 2013 7:51 pm
by Kaptein
Hi
Minor update (but allot of work).So I finnished al the metal work on the pan,wire wheeled the pan and then cleaned sanded and painted it with red oxide.
And before I painted the pan I lowered the rear torsion bars 1 notch :hangloose:
Tomorrow I'll seam seal all the necessary edges and paint it all in gloss black
Cheers
Ferdinand
Re: Projek '63
Posted: Sun May 19, 2013 11:56 am
by mojo1963
Nice to see the excellent job youre doing. Well done!!! looking foward to seeing the rest of the build. :hangloose:
Re: Projek '63
Posted: Sun May 19, 2013 1:45 pm
by Ron&Gill
It's a fantastic job, but I don't agree with what you've done with the hole in the tunnel. It looks tidy, but it is, in my opinion, not wise to hold together the car's structure with four pop rivets. You should have welded it closed for a stock repair. It is not needed at all to have a hole there (otherwise VW would have put one there). Putting the clutch cable on without the hole is very easy if you know how.
Best of luck further, it looks like it will be a very nice project.
Re: Projek '63
Posted: Mon May 27, 2013 10:04 pm
by Kaptein
Update
seam sealed all the joints
Stone chipped the pan
In the sun drying for 2 days before final coat
Final coat on and in sun to dry.I used Glasurit Hochglanz schwarz(high gloss black) I think thats what the factory used back then
Painted the beam ect.
I had some of the bolts/fittings electroplated and assembled the beam with new poly seals
Next-do king and link pins,assemble pedal assembly,fit engine and gearbox
Ferdinand
Re: Projek '63
Posted: Mon Jul 01, 2013 7:16 pm
by Kaptein
FOR SALE
Re: Projek '63
Posted: Wed Jul 03, 2013 7:56 am
by flatfourfan
this is a real shame, you put tonnes of work into this and I really liked where it was going. Good luck with the sale though bud.
