1959 Bus
sean
Has thanked: 63 times
Been thanked: 227 times
Re: 1959 Bus
Post by sean »
Wow, very interesting. Looks like a nice find. :hangloose:
Those scoops on the roof look identical, but difficult to make out in the picture but is it some sort of sheet metal going across between the two scoops?
Eugene
Has thanked: 59 times
Been thanked: 65 times
Re: 1959 Bus
Post by Eugene »
Nice find Sean
Whatever you do, keep those ears!!!
Tony Z wrote:awesome!!! Good find.
no roads or trails leading to it... makes me wonder how it got there in the first place.
Sure it got there in under 2 hours :hangloose:
hendriks
Been thanked: 13 times
Re: 1959 Bus
Post by hendriks »
Hi Sean,
please post pics regularly on this project. I think several people will be keeping their eyes on this one..
Can't wait to see it on the road.....one day. What a story to tell... :hangloose:
sean
Re: 1959 Bus
Post by sean »
So, here is my donor bus to get my 59 on the road again. :hangloose:
Firtst question: Am I able to bolt the front suspension over as well as the gearbox, spring plates and torsion bars from a fleetline onto a 59 :?:
Klaus
1959 Bus
Post by Klaus »
sean wrote:So, here is my donor bus to get my 59 on the road again. :hangloose:
Looks like a nice donor bus.... Sure you want to cut it up?
Would love a panel if you want to move it on to raise funds for the project.
MINCE
Re: 1959 Bus
Post by MINCE »
Looks like your donor bus had a watercooled motor in it
Danie Beetle
What model do you have?: 1963 Baja
Re: 1959 Bus
Post by Danie Beetle »
nice find
Wow What a trip :hangloose:
Danie Visagie
082 94449 00
Re: 1959 Bus
sean wrote:Firtst question: Am I able to bolt the front suspension over as well as the gearbox, spring plates and torsion bars from a fleetline onto a 59 :?:
I think all those bits will bolt up except the gearbox. If the bus was built after 4/59 then it will have the later front trans mount and the Fleetline box will fit. If it's earlier then you'll have to fab a new front mount and shift rod.
@Klaus, that donor bus is totally rotten, as only a coastal bus can be.
Klaus
1959 Bus
Post by Klaus »
fig wrote:
@Fig, Looked okay from the front but sad if its all rotten. At least it's going to save an awesome early bus. Hope the vents at the back will remain with the bus to keep it's history.
@Sean, are there any bits of the donor that you won't be using? My fleety could do with some patina'd bumpers :)
sean
Re: 1959 Bus
Post by sean »
Thanks Fig
If I remember it was a late 59 according to the VIN number, so seems pretty positive so far.
@Klaus, that picture was taken a while back and the bus looks substantially worse even though at that time it was completely rotten covered up with foam, newspapers and fiberglass or was it even household roof materials. Once the 59 is complete I will for sure share the parts left over.
Klaus
1959 Bus
Post by Klaus »
You're a champ!
Good luck with the build.... Gonna be awesome when it's finished
sean
Re: 1959 Bus
Post by sean »
So, the other day I went to collect the “donor bus” for its running gear for my 59. I hired the trailer and brought the bus back to my place.
Last weekend and this weekend I stripped the suspension and transferred it over to the 59. The front suspension was an easy bolt over but unfortunately I have the early gearbox mounting and the fleetline gearbox doesn’t fit. Drat. Still, I installed it and the reduction gearboxes at least bolted to the spring plates that I could move it. :?
As I had to move it around to the other side of my house which meant I had to move it on the road, which involves a steep downhill and then up again and while having no brakes left me concerned. After a number of idea’s Tonia towed me out with Land Rover and we decided to walk it along the pavement down the road and regularly nudge the pavement to slow it down. I just had all these thoughts of this bus rolling into the back of my car trying to tow it. We made it round and we towed it back up the other side, luckily uneventful.
Leaving the garden where it had waited the for the last year, it had already waited 20 years in the bush though. :shock:
As it was looking so good with wheels I gave it a good polish and wax to see how the paint still looks, plus adding the headlights. I think that patina looks stunning and I am so chuffed this bus will be on the road again someday as well as being dry in the garage now. :D :D
You can see the small spot on the bootlid after cleaning some of the tractor paint off, it seems the paint is still good underneath, just got to complete it. It takes time but luckily it is some kind of waterbased paint which is easy enough to remove.
I am so glad I have been able to add this one to my small bus collection, I just have to get it on the road to match the others...
Re: 1959 Bus
8) Well done man, this is going to be a very interesting project, looking forward to seeing the progress. Amazing - the transformation now that the '59 on wheels, with bumper and headlights. Very keen to see what is happening under that secondary layer of paint, that Dove Blue with patina is going to look wicked :hangloose:
sean
Re: 1959 Bus
Post by sean »
jolas wrote:8) Well done man, this is going to be a very interesting project, looking forward to seeing the progress. Amazing - the transformation now that the '59 on wheels, with bumper and headlights. Very keen to see what is happening under that secondary layer of paint, that Dove Blue with patina is going to look wicked :hangloose:
Is it Dove Blue? It looks more grey to me. :?
Perhaps Fig can share a bit more info on this coulour...
The darker colour coming through is grey primer.
My rims should hopefully arrive next week which I can get started with.
As far as I know: The rims should be white like my bumper while the hubcaps being grey like the body. Is this correct too?
Sean
jahjuan
What model do you have?: 73 Kombi
Re: 1959 Bus
Post by jahjuan »
Nice one, good luck for the build.
Isn't the colour mouse grey?
