Page 3 of 104
Posted: Thu Jun 18, 2009 5:44 pm
by mahleu
Replaced a broken battery terminal connection and put in a scary amount of oil and water. Also put a diplomatic piece of cardboard underneath to catch leaks
Posted: Thu Jun 18, 2009 8:20 pm
by Cyberbeast
Washed my car today... looks good once again...
Posted: Thu Jun 18, 2009 9:47 pm
by lowlight
Nothing. Come home tonight, no power,sit with laptome and candle power.
Posted: Thu Jun 18, 2009 10:08 pm
by Dirk
Made a set of white reflectors for Christn. Much the same way I did for Lady.
Posted: Thu Jun 18, 2009 10:24 pm
by 1972
Dirk wrote:Made a set of white reflectors for Christn. Much the same way I did for Lady.
oh dirk to tell us how do tell
Posted: Thu Jun 18, 2009 10:37 pm
by Dirk
Shane, they don't look at all the same as the original ones. They are simply about the same size.
I've taken photos and will post the story on my site. Will let you know when it's done.
Posted: Thu Jun 18, 2009 11:22 pm
by Dirk
Shane,
I've posted it, you can read about it here:
http://djb.co.za/?q=node/29
Posted: Fri Jun 19, 2009 9:38 am
by 1972
thanks Dirk
Posted: Fri Jun 19, 2009 10:38 pm
by lowlight
got metal pipe that goes from reservoir to the master and bleed brakes. Really helps if there is a second pair of feet around. Had to do it on my own. Tonight another romantic night without power.
Posted: Fri Jun 19, 2009 10:40 pm
by Dirk
Took the fasty gearbox appart so I can send it to get Buggered
Posted: Sat Jun 20, 2009 11:33 pm
by Dirk
Today I cut new top-front door panels for Christn. I ran out of hard-board so I could not do the rest. But then I turned my attention to the parcel try. Striped it and started sanding it down.
Posted: Sun Jun 21, 2009 6:32 am
by Hloni
Took her out for a dougnut session, now engine is blinkin dusty! ah...
Posted: Sun Jun 21, 2009 4:00 pm
by Dirk
Did an oil change on Lady this morning. I swear she smiled at me when I was done
noting how much better I've become at it since doing my first one about a year ago.
Posted: Sun Jun 21, 2009 5:05 pm
by 1972
i spent my day on the start of a body roller for my beetle more to come in my build thread later
Posted: Sun Jun 28, 2009 7:30 pm
by Dirk
Dropped off Christn's gearbox at HR's, then came home to put Lady's repaired right rear wheel back where it belongs. The spare wheel is also back where it belongs.
Then I left Lady wide open in the sun so she can get rid of some of the trapped moisture in her.
