suicyde engine
davetapson
Re: suicyde engine
Post by davetapson »
Tony Z wrote:So far the car has been doing fairly well but popping and staling at 4000rpm. So I decided to pull the carbs and fan housing.
I changed the manifolds for the big ones, cut the fan shroud a little to make it fit better and installed new spark plugs and leads.
Today I hit the 500km mark. With the new bits, she revs easily up to 5500. This without pushing her too hard. The carbs are so loud that they set off car alarms when I open up the throttle. My ears are ringing. 150km/h without blinking. I accidentaly did a 20m wheel spin cutting in front of some moving traffic, in second gear - OK was turning a corners, so one tyre came loose, but its still a novelty.
I cant wait to do another 500km and then get it onto the dyno for a power run.
Sounds Awesome...!!
Re: suicyde engine
Post by 1972 »
Tony just a few qeustions that i think you might be able to answer for me...
On a mild 1600 would it be better to run straight cut gears or the original style slanted gears?
Then...Can you keep the orginal oil cooler that sits in the doghouse and then still be able to attach a filter and cooler, sort of on one line?
Like this...
Would i need a bigger oil pump for the above?
Re: suicyde engine
the pic you posted is OK for an external oil cooler, but you would be better off adding in a thermostat. IMO on a mild 1600 there is no need for an external cooler if your cooling tin is all in place - I never needed one before.
You can use a stock oil pump, but a few small mods to it to make it flow better wouldnt hurt, but also not really needed.
What exactly are you trying to do to the 1600? I can answer better when I know more.
Stock cam gear is ok. Straight gears are noisy and annoying, which is why I dont use them on my 2332. wont hurt to use them, but not needed. Run a double thrust cam bearing (cheaper to buy 2 sets of stock bearings and use both the thrust bearings and throw the extras away than to buy a double thrust kit) - the straight cut gears are only really needed when you run super high spring pressures which wont be needed on a mild 1600.
Re: suicyde engine
Post by 1972 »
Thanks Tony
This is more or less whats going to happen
Rebuilt engine consisting of...
Line bored case
re machined flywheel
re machined crank
re sized and rebushed conrods
new piston and sleeve kit
new oil pump
remachined lifters
8 new pushrod tubes
new valves if needed and new guides
4 new sparkplugs
new oil pump
refaced oil pump cover
Then...
Engle 110 type cam
2 sp type carbs or 40mm Kadrons
branch type exhaust and a mild port an polishwith a flycut
8 hd valve springs
Edmond
Has thanked: 22 times
Been thanked: 41 times
Re: suicyde engine
Post by Edmond »
Specs looks similar to my mild street 1600 build
Re: suicyde engine
Post by 1972 »
Thats the run down IMPI sent me on a mild 1600 engine build
dubster
Re: suicyde engine
Post by dubster »
Tony love the car,can only imagine that motor in a buggy...should be insane...shane start a thread,than we can all have nice debate over what to do and what not to do...dont wanna jack tony's thread...but ive got a similar motor,and believe me it runs well without that fancy stuff...
1974 1300tp type 1
kart kraft 1717cc buggy
Re: suicyde engine
1972 wrote: new valves if needed and new guides
Dude, dont skimp here. Its not expensive, get new valves. If one exh valve is tired, it will break and kill the whole engine.
If you are keeping the stock pushrods, keep stock springs. HD springs need HD pushrods.
I would also get the crank counterweighted.
And yes, as dubster says... start a new thread.
more info and pics you can use here
vader
Re: suicyde engine
Post by vader »
All this technical stuff is making my eyes go wonkie....
So here is something to help them refocus......
Have a look at chrome domes mechanic....
Im sure y'all will like ......
Re: suicyde engine
this thread is slowly coming to an end.... follow the other progressions here http://www.aircooledvwsa.co.za/viewtopi ... 23&t=14775
Re: suicyde engine
Tony Z wrote:this thread is slowly coming to an end.... follow the other progressions here http://www.aircooledvwsa.co.za/viewtopi ... 23&t=14775
You mean...uhm.... like.... you know... ... uhm.... how can I put it?..... uhm, as in...............just like............uhm ...... the THREAD being suicydal?? :shock:
Re: suicyde engine
No Pine.... as in the engine is running and not much left to do to it (until I go turbo).
BTW, a name change is also on the cards, as Suicyde has been the name since day 1. The car has taken on a completely new character and is now just angry....
Re: suicyde engine
How 'bout ZORNIG, then - it is German for ANGRY?
(but it also means angry; mad; wrathful; irate & furious) :wink:
Re: suicyde engine
more info to come later....
Re: suicyde engine
and today while doing 140 on the highway.... oil pressure light comes on.
No leaks, oil sump full.... pump not pumping. Lets hold thumbs that nothing is broken.... and to top it off, my other car is getting a new clutch today, so I have no transport.
Big thanks to Thumper for fetching me and towing the car to his work... more info to follow once I get my car back and can see whats wrong with the beetle.
