Page 14 of 28
Re: 67 Panelvan
Posted: Mon Jan 09, 2012 8:36 pm
by Donovan D
Klaus wrote:Cool, most of the folk going down there should be a figs the next week so would be awesome. Can you send me you bank details via PM and I can drop you some beer money?
Dont worry about it, I dont have any use for it, and got it for free. Do you want the surround and the cover aswell or just the sink ?
Will find out who of the CT crowd is going
Re: 67 Panelvan
Posted: Mon Jan 09, 2012 8:45 pm
Splitz wrote:
In CT, if anyone from jhb and ct going to the george show I can send it with them.
I can take it to George
Re: 67 Panelvan
Posted: Mon Jan 09, 2012 9:02 pm
by Donovan D
Thanks a lot Tony, please forward me your number so we can arrange meeting.
Re: 67 Panelvan
Posted: Mon Jan 09, 2012 9:21 pm
pm sent
67 Panelvan
Posted: Mon Jan 09, 2012 9:49 pm
by Klaus
Splitz wrote:Klaus wrote:Cool, most of the folk going down there should be a figs the next week so would be awesome. Can you send me you bank details via PM and I can drop you some beer money?
Will take what you don't want if that cool. If you want I can get a courier to pick it up if it cause any hassles for you
67 Panelvan
by Klaus
Tony Z wrote:pm sent
You guys are champions !
67 Panelvan
Posted: Mon Jan 09, 2012 9:53 pm
by Klaus
Bugger said he will be able to bring it up to JHB from George.
Awesome group of people we have here !
Re: 67 Panelvan
Posted: Wed Feb 01, 2012 10:39 pm
by Donovan D
Got myself a new exhaust after a lot of debate. Its a much better setup.
The old one did about 600km so if anyone is interested let me know.
Its sounds k@k, actually its very quiet. But I do mis that mean sound of the previous exhaust.
Re: 67 Panelvan
Posted: Wed Feb 01, 2012 10:57 pm
by jolas
Did you buy it locally Donovan ? I'm also having second thoughts about mine ..........
Re: 67 Panelvan
Posted: Wed Feb 01, 2012 11:04 pm
by Donovan D
jolas wrote:Did you buy it locally Donovan ? I'm also having second thoughts about mine ..........
Yes, got it from Dave Rowley
Re: 67 Panelvan
Posted: Wed May 16, 2012 5:24 pm
by Donovan D
I have realised that 4th gear is labouring the engine and the cause for the heat.
If I cruise in 3rd at 50mph at 3000rpm the engine is cold and I can keep my hand on everything in the engine bay. As soons a I go into 4th it starts getting hot.
I currently have a 4.125 gearbox in, would a 4.375 help with the 4th ?
Other than that not much has been happening.
I replaced the roofrack slats as the old ones were dodgy and starting to go missing after trips. The kombi also needs a proper clean, maybe even a sand down and clear coat....fed up with the dust sticking to it. Also fitted some spots to the kombi.
Some pics
Re: 67 Panelvan
Posted: Thu May 17, 2012 7:33 am
by GavinHuart
Awesome! I LOVE that bus! Dying for a rear roof rack for mine but we all know how hard they are to come by
Re: 67 Panelvan
Posted: Sun May 20, 2012 12:14 am
by Dawie
If you want to change to a 4.375/ (1300) gearbox, then look for a SFAR code one.
Some of them came with the same 0.93 4th gear as the late 1600. I tested the ratios on a 77 1300 box, and it had the 0.93 4th even though the owner's manual that came with the car said 0.89.
The 4.375 ratio will give about 6% more revs than the 4.125. If you find one with 0.93 4th in stead of the 0.89, total difference will be around 10% more engine revs at the same speed.
Th test which SFAR box it is, put in 4th gear. (If box is out of car, use pliers or vice grip on selector shaft and put old clutch disc on input splines). Block one drum from turning and lift the other one and mark it's position. Now turn engine or input shaft until drum has turned exactly 2 turns. (Because of diff action when one wheel is blocked, other one turns 2X). If box has the 0.89 4th, input shaft will do 3.89 turns for 2 turns at drum. If 4th is the 0.93 we want, then 4.07 input shaft turns will correspond to 2 turns at drum.
Re: 67 Panelvan
Posted: Sun Jun 08, 2014 9:52 am
by Donovan D
Everything on this kombi is running good, still some tweaking with the engine to get it to run nice enough so that I can get the confidence to take it on a long trip.
Since then I have been adding some more weight to it. Got a full length rack from Jolas and been busy tinkering on some stuff around the kombi.
Dug up the old specs on the Hurst bumpers which Ive had for a couple of years now and started the build. Was quite a mission getting these specs off the guys abroad.
Mr "JeremyRockJock" from theSamba was kind enough to supply the cad drawings.
All the steel for this was not even R250. Had a good scratch around at Brackenfell Staal's off cut bins.
Encountered a problem as no one could do the bends with the radius and degrees. Got hold of Zahier of
http://www.flywheelbikes.co.za/ , local bike builder and he was able to bend the pipes for me
Still in Progress:
Re: 67 Panelvan
Posted: Sun Jun 08, 2014 10:21 am
nice!
