Posted: Tue Nov 11, 2008 7:20 am
13 and 14 is the numbers used for the assembly in the VW Manuel.
*Bolt M8 fits in hole 13 and 14*
Forum for Aircooled VW enthusiasts
https://www.aircooledvwsa.co.za/
Thanks Chris, that makes sense. So it is something like 'build by numbers'?Chris wrote:13 and 14 is the numbers used for the assembly in the VW Manuel.
Newly overhauled Lycoming O-360 A1A for Sale. Hollow crank - ready for constant speed or fixed pitch propeller. Dyna-focal engine mounts ideal for RV's, Sportsman 2+2, Glasair and many other homebuilts. Hrs SMOH 0. New light weight Sky-Tech starter. New light weight alternator. New Harness kit. New mags. 100 Hour Warranty by Superior Millenium Aircraft Engines. Can be used in the certified category but add R15,000 for certification. Will ship anywhere in SA for free.
[/quote]Pine wrote: 100 Hour Warranty by Superior Millenium Aircraft Engines.
Pine wrote:With the front suspension and wheels removed, it is quite easy to turn it on its side, and support it with a piece of water pipe to make working underneath it more easier.
