1964 Notch - The green goblin
- Riekert
- Camshaft
- What model do you have?: 1964 Notch
- Has thanked: 111 times
- Been thanked: 23 times
Re: 1964 Notch - The green goblin
So tried fitting the beetle geni... :/ need to modify things a tad. But should work. Hopefully ill get to start it this week
- Riekert
- Camshaft
So got some work done albiet not much...
beetle geni fitted.
Had to mod the pulley to clear the couwling.
Also fitted the empi distributer cap. Now just coil, plugleads and fuel line. Then she can start!
beetle geni fitted.
- Has thanked: 78 times
- Been thanked: 37 times
Coming along nicely.
Your goodies are on there way keep a lookout for them
- Riekert
- Camshaft
Thanx! And will do!!64 Notchback wrote:Coming along nicely.
Trade for a lowered Golf Mk2 maybe? looking good man, can't wait to see it running
Hahaha will send some when the new wheels are on
I would love another Type 3 but until I can organise some kind of covered garage for it, not going to happen.
- Riekert
- Camshaft
So added some new plug wires in the notch. And mounted the coil. Tried to start but my sparkplugs are stuffed so need to get new ones.
But so far so good. Also gave the goblin a wash
- Riekert
- Camshaft
So got new plugs and still nothing. sigh... ah well will look again this weekend. I've got another issue. The carb is leaking fuel out the front so think there might be a issue....
I can spot another problem.... that dizzy cap. Replace it with a stock unit from Midas. Your pretty one will leave you stranded.
You can have a nice blue dissy top, but not that type.Riekert wrote:Really? Damn... ok cool thanx. Still have a newish stock one
Take you stock std. one from Midas, tape up to the level of your rubber wire socks, and spray it, do not get paint inside, and then remove tape, so that no paint is under the wire socks.
Hey!!!! Presto.... cool looking dissy cap that will not drop you in the when you least can afford it.
