Surge
Re: My type 1 turbo project
Post by Surge »
4agedub wrote: One other nifty trick I used on my red bug. The gear shift has been relocated closer to the seat and lifted up slightly. No more bending over to reach the gear lever. :wink:
Now that is a smart mod that I'd consider doing as well. The gear lever in a beetle is too far forward for us long legged people who have the seat slid right back.
I actually find myself hunched over the steering wheel most of the time.
How do you connect the shift rod to the gearbox?
Do you cut a slot in the tunnel further back? :shock:
4agedub
Been thanked: 13 times
Post by 4agedub »
I shortened the std beetle shift rod and bent it a bit. I had to cut a slot for the rod to pass through. Also my tranny is lifted a bit for the rear camber compensation, so that also helps a to connect the shift rod on the top.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
4agedub
Post by 4agedub »
Some more news... I got the turbo exhaust flanges today, so this weekend I can finish my exhaust :hangloose:
vuyo
Facebook: vuyo dube
Post by vuyo »
sweet :hangloose:
60s look 74 beetle
skype: afronotch
4agedub
Post by 4agedub »
Here's a pic of the shift rod at the back.
Surge
Post by Surge »
4agedub wrote:Here's a pic of the shift rod at the back.
Cool. Not as bad as I thought.
Does reverse still work?
I'm not sure of the motion the reverse selection makes on the shaft but I assume it's only an extra twist?
4agedub
Post by 4agedub »
The reverse still works. :wink:
imraan
What model do you have?: 1974
Re:
Post by imraan »
flatfourfan wrote:awesome, be sure to post TONNES of pics......the best my 1.5 VTEC ever did down westbank was 16.8.
Niiiiiiiiiiiiiice.
Hi freind thear is a beetle in capetown 2.3cc with no turbo that did in the late 12s that i now has got magnum 044 heads ets that is fast
1.5 VTEC?
Ron Metz's maybe imraan?
4agedub
Post by 4agedub »
In Cape Town you got the advantage of sea level... we're at 4000ft above sea level. But still 12's are good. :wink:
Wrong Eben. Ron Metz does not have a beetle. Maybe you are thinking of the ex Dave Ingle Beetle.
The ex dave ingle car is the original Blitzkrieg Beetle :wink:
2BugMe
Post by 2BugMe »
Hey 4age....
Things are coming on nicely with your fasty?? 8)
2 things I would like to ask:
1: What are those pipes coming out of your tranny as per your pic of the bent gear shaft above??? Turbo? Oil cooler??
2: Are those second hand 90.5's still available?? and at what price. I will be up in Joburg on the weekend and would like to see them if they still available..
Shot :mrgreen:
