1962 T1 resto cal project
- What model do you have?: 62
- Has thanked: 8 times
- Been thanked: 14 times
Re: 1962 T1 resto cal project
Not the easiest colour to match, but after trims were added not really visible
Sent from my CLT-L29 using Tapatalk
nice!!!
OK, spill the beans.... where did you get Koni's in SA? Or am I seeing it wrong?
I've really enjoyed driving Klaus in stock form for the last year or so but it is now time for a little show and a lot more Go! The plan is for any mods that will be done to be easily undone. Nothing original wil be cut or modified, the motor will be dropped out and replaced, even the instruments are installed in a way that fits directly into the radio opening.
I'm going for a vintage spped look and because of the dropped spindles the 356 Repro 4.5 j wheels up front would not work so I had to build a narrowed front end, now she sits just right and I am busy with the new motor.
Heu Tony, you're seeing right, special D gas adjust, get them from these guys, they are amazing I use them on both my bugs. Also put the part numbers you need.Tony Z wrote:OK, spill the beans.... where did you get Koni's in SA? Or am I seeing it wrong?
I had them reupholstered to match the door cards. In vinylRiaan.N wrote:Very very nice! I like those seats Is it still the original leather?
Thank you sir, yes I did, used with a very tiny bit of matting agent to match the old paint.73type2 wrote:Nicely done 62RestCal! Did you use 2K paint?
