Page 101 of 104
Posted: Fri Apr 28, 2017 7:27 pm
by John Alves
Today I decided to make individual hand brake levers for my buggy, (diff lock) works better than expected, now I can lock the spinning wheel and transfer
power to other wheel, hand brake works in the normal way, but individual levers work in opposite direction. I must find some nice round handles to finish it off
Posted: Sun Jun 25, 2017 6:07 pm
by freddiebooysen
So started trying to do some bumper repairs
First started with the over spray on the bumper steps on blue
Before
Some elbow crease and they turned out better
Started swearing when I saw the bumper again and tackled it with a new grinder and old hammer
You can clearly see steel was a lot cheaper then as they build this thing up
Welding was functional
Finally got the radiator off
Then had to get these grinder off being careful to preserve as much of the bumper as I could
And after all that here is what I could salvage
Will see what we can do to get this welded again and filled in
The brackets also had been strengthened to hold the weight of the radiator so will make a plan with those as well
Well that is what I did to blue today
Thanks for reading
72 - Freddie Booysen
72 Bay - unnamed WIP
72 D/C - Blue abomination!
74 Beetle - BEE
Posted: Sun Jun 25, 2017 7:33 pm
Why not move the radiator now you have it off and ask Pierre at bugger transmissions to show you how to do it.
The bus will look much better with the hidden radiator and clean nose.
Posted: Sun Jun 25, 2017 8:05 pm
by freddiebooysen
Herman. Dankie. Die radiator kom af gaan terug aircooled toe. Raak sommer weer van voor af kwaad oor die radiator voor op die bumper. Hulle het die blerrie ding op geneuk. Meer skade as goed
74 Beetle - BEE
Posted: Mon Jun 26, 2017 5:19 am
by FaanP
Fitted my engine with some help from the VW roadrunners. Adjusted my pedals yesterday - not fun job. Will post tonight on my build thread
Posted: Sun May 13, 2018 7:27 pm
by stew 89
New clutch cable, made a bushing out of nylon to prevent future cable failure. And gave the old girl a wash.
A good day
Posted: Sun May 13, 2018 7:47 pm
by jolas
stew 89 wrote: Sun May 13, 2018 7:27 pm
A good day
Hi Stew, can you explain more about this ? is this bushing at the front or rear ?
Cheers
Posted: Sun May 13, 2018 7:57 pm
by stew 89
[/quote]
Cheers
[/quote]
So at the rear where the cable exits metal tube and enters the flex tube that goes up to the clutch lever. Right at the junction between the two. in my case the metal tube has had quite a lot of ware from the cable resulting in a sharp edge that has been chewing through the cable. I made a round bushing that fits in the flex tube junction and snugly around the cable. the hope is that this will stop the cable from getting stuck in the sharp metal tube.
Its just a round bushing with a pie shape cut out of it to slide over the cable. I made two if you want ill take a pick of it.
Posted: Sun May 13, 2018 8:01 pm
by jolas
Ah thanks man, I get it
Posted: Sat Aug 03, 2019 6:40 pm
NOTHING ..........
Absolutely nothing ....
Has the 1st year birthday party with my granddaughter.....
Posted: Sun Aug 04, 2019 4:16 pm
by John Alves
replaced headlight bulb and polished Ghia for an upcoming Matric Dance outing.
Posted: Wed Aug 07, 2019 9:09 am
by Batman
Fitted tyres on the newly painted front rims....
Posted: Wed Aug 07, 2019 1:08 pm
by Batman
This is what 175/50/15 look like on steelies
Posted: Wed Aug 07, 2019 2:43 pm
by acpaterson
Un-covered him and started him for the first time in a few months.. I love my Kombi.. So reliable..
Posted: Sun Aug 11, 2019 6:08 pm
by Haans
Busy with the piping & cooler
Next on to electrics,......check out the "fit for purpose spanner"
