Were you referring to the little 'o'-ring at the shaft of the dizzy? Do you have excessive sump compression?
Yes,that seal.But it was just worn and rock hard.
HEY !!!!!!!! that was my drive way, yours was already used on monday last week !!!!!!!!!!!!!!
YesPine wrote:A 2min operation! Right?
My driveway looked a LOT worse!Bad Ass Bob wrote:HEY !!!!!!!! that was my drive way, yours was already used on monday last week !!!!!!!!!!!!!!
You had a small little spot.
Was still my drive way, question is who is next ????
- Hloni
- Has thanked: 14 times
- Been thanked: 11 times
Man didi what a man had to do just before sunset today. Will see what she looks like tomorrow once the sun has risen.!!Hloni wrote:Sure for that R&G, am goin' into the city today to get the stuff. Might also get NS1/NS2 which Chris swears byRon&Gill wrote:Wash the area with caustic to neutralize the acid, then with soap and water, don't spare the water. (the solution to polution is dilution) Use the caustic, you know what happens to your jeans when you get acid on them, everytime you wash them, the hole gets bigger! This only stops when you soak them in caustic, why should your battery tray be any different......
- Ron&Gill
- Been thanked: 21 times
Tell me how you made out...Hloni wrote:Man didi what a man had to do just before sunset today. Will see what she looks like tomorrow once the sun has risen.!!Hloni wrote:Sure for that R&G, am goin' into the city today to get the stuff. Might also get NS1/NS2 which Chris swears byRon&Gill wrote:Wash the area with caustic to neutralize the acid, then with soap and water, don't spare the water. (the solution to polution is dilution) Use the caustic, you know what happens to your jeans when you get acid on them, everytime you wash them, the hole gets bigger! This only stops when you soak them in caustic, why should your battery tray be any different......
- Hloni
- beetlefanatic
- Has thanked: 8 times
- Been thanked: 12 times
On the way home from the airport I decided to get the split out of storage and drive it to charge the battery. Went to fetch my daughter from school with it and on the way back it died in the center of the traffic intersection and did not want to start again. I had to push it to the side of the road with people honking etc. Found that the starter solenoid wire had come loose. Still could not get it started and almost drained the battery. Eventually got it going by pouring some fuel into the carb, but it did not want to idle at all. Luckily I could get home by keeping the revs up. So a fun drive turned into pain in the ass. Tomorrow I need to clean the carb and fit a new brake slave cylinder as on top of everything, I saw that the right rear wheel was wet with brake fluid.
removed my exhaust and the oil piping to my remote filter....
1 step forward, 2 steps back
Welcome back Bernard.
- beetlefanatic
Chris wrote:Welcome back Bernard.
Thanks guys!Blitzkrieg wrote:Welcome back Uncle BF!
Uncle?
So hopefully after the weekend I'll be able to add something to this thread everyday. The cabrio is coming out of storage tomorrow.
Mocked up my exhaust and spent the day putting on heat wrap
