Replacement for Seatcover`s Stolen one
Re: Replacement for Seatcover`s Stolen one
Picked up front w/bearings today and will be fitting those tomorrow and adjusting the K&Link pins and check play on them
Want to try and finish the motor aswell Alternator asembled and tested with new bearings :D
Have to fit the engin comp seals which is a sh t job
Do side shaft seal kitts to make sure the gearbox oil stays in side aswell as the axle boots
Well have to see how far I get may be we can drive it on the run on sunday :D
Well not using her on the run tomorrow still a few things to do to get her reliable for the seatcover
Started with the front wheel bearings and saw the slave sylinders are little moisty so went and got front and back new ones and not the rubber hoses they looked brand new
So on the way home I said to myself I just should have gotten new rubber hoses and klaar na nee my own ass must get a kick when I got home thought just stripp everything ells off and check the hoses :shock: so much muck in there cant even get the compressed air to blow through
then gat buzy with the rear fitted new Side shaft seal kits they are always prone to leak and I dont want any oil leaks on the new refurb mags :D had a set of brake drums and shoes in stock that Was skimmed and relined and used them with the new slave cylinders
I have learnt out of previous experience that when you fir mag wheels with Adapter plates on a bug it is one hell of a mission to adjust the brakes when they get low
What I did was drilled a hole at each adjuster in the backing plate so you do not need to remove wheel and adapter to adjust brakes :D
Got the back wheels on to see how they look on the bug and they are looking CCCCWEEEET :D
The wheels are stickking out slightly so have to make a plan about that wider fender or short side shafts in the back
First want to get the motor inn next week and see how the bug sits with the weight of the motor inn then will see what I can do might take a little meat off the back of the rims if there is enough strength left
As can be seen on the top pic the left front fender is repaired and looking good again :D
Now not to long for it to run :D
Jeez, Pierre, you got big feet. lol.
Lol, those are very nice wheels btw.
Wow Buddy,good work.
karmakoma wrote:Lol, those are very nice wheels btw.
Hopefully they wont get Ziked to Quick
Well got the brakes and all sorted done the wheel bearings and re fitted all the drums adapters on and all 4 wheels fitted and this bug is looking really super with the BIG FEET on him
I installed the motor after I replaced the 6V flywheel that was on the motor from the donor bug and all the look fast goodies when I started the motor there was one helluva rumble thought the fan was loose that I did not tighten it enough
which would be very unlicly removed the fan belt started the bug again and still with the rumble :shock:
Now I knew it was the flywheel that was loose but How it could be I could not under stand so lost a bit of interrested for a day or so
Well ripped the motor out last night and walla flywheel nut was broken when FrisChris tightend it :oops:
So now the crank was Damaged and the Fly wheel :twisted:
I used the pencil grinder and flattend the burrs on the crank and used a new Flywheel that was still lekker :D and Some trusted Locktite reasembled all and chucked the motor back in the bug :D
And started up on the first turn :hangloose: and sounds very nice with out any Rumbles now just need to fit a new Vacuun advance and all the vacuum hoses and Airfilter and give it a bit of a tune and the test drive :arrow:
Then on Sunday to cars in the park I will use Beetlefanatics (MY new Company Car :D ) While he is Out a country and the Wive can drive her bug there to get some shake down Km on the bug for the Cremlins that always Stick their heads out
Will post some Pics of the bug later
Bad Ass Bob
Post by Bad Ass Bob »
Awsome news Bugger, tell Rene happy motoring...................................BAB :hangloose: :drunks: :mrgreen: :D :lol:
Enjoy it on Sunday.
beesbal
Oil Seal
Post by beesbal »
hey Bugger,what happend to the first black bug from your post
beesbal wrote:hey Bugger,what happend to the first black bug from your post
Sold it to a friend of the inn laws
