Beetlefanatic`s Cabrio
Re: Beetlefanatic`s Cabrio By Bugger
Seems that you need to start stocking up on those the hart pilletjies that is HEHEHe
Has thanked: 36 times
Been thanked: 50 times
Post by flatfourfan »
lmao.............nice ride.............
Bugger wrote:Seems that you need to start stocking up on those the hart pilletjies that is HEHEHe
On second thought the Kazakh vodka is just as good for the heart and you don't have to go see doctor. Well maybe afterwards. :drunks:
Thanks FFF. With Bugger's help I'm sure it's going to be a stunner. Can't wait to get to the backside. That's were the real fun is going to be. :hangloose:
Santa stoped past today and droped off some spares
Will post some pics soon
Some Heavy duty running boards these things are blessing they are basicaly OE thick steel and strong it was the first time I sow this imported coz every one brings inn these cheap thin plate running boards
And some Alliminium Back calipers :shock: :wink: these things are beautifull I want to frame them and hang them up
The tail light lens assemblies I got OE as well for the price differance between the brazil import and the OE when the bug was painted I did the Elephant feet holders so that is what is going on ye one always want to put the smaller ones on but a new set of Elephant feet lail lights looks very good aswell
Got some Bosch Brake pads :D so the stopping power is going to be up the bar with vents up front
This is before the stickers are removed and the valet
Here is Beetlefanatics bay bus aswell
And after this actually a very nice buy drives nice and not been butcherd
Just the seats has seen the best of days
Some more updates Later
From what car did those calipers come off?
SUZIE
Post by SUZIE »
You need Grossdrilled ventilated discs to go with those calipers!!!
Blitz I think Bugger got them at VS, but not sure from which car.
Crossdrilled disc look very cool. I was going to put vented discs in front and solids at the back, but maybe crossdrilled fronts will look nicer.
SUZIE
Post by SUZIE »
Hi Beetlefanatic
Brand new (Alfa make) crossdrille ventilated is R150 each and for solids is R130 each, the more you take the more you will safe on P&P
I am busy fitting crossdrilled ventilated to my golf for better brake performance, used to use only crossdrilled discs on all of my Mazda's, well even my Isuzu had crossdriled discs
Hi Suzie,
Thanks , are they 4x100pcd? I check with Bugger if he hasn't bought them yet.
I bought the normal vented ones could not get drilled ones where do you get the drilled ones
vader
Post by vader »
Well you take a set of disks choose a drill bit, take it over to the drill press, center punch your pattern onto them, drill away and hay presto you have crossdrilled disks...
SUZIE
Post by SUZIE »
beetlefanatic wrote:Hi Suzie,
Yes they are 4 x 100 PCD
SUZIE
Post by SUZIE »
I Have some little connetions here in Newcastle that seply me with them
SUZIE
Post by SUZIE »
vader wrote:Well you take a set of disks choose a drill bit, take it over to the drill press, center punch your pattern onto them, drill away and hay presto you have crossdrilled disks...
Centre punch can cause cracks in disc's that you cant see and will develope bigger cracks as you use them.
left is different from right side, discs are marked for left use and for right hand use
Bugger wrote:I bought the normal vented ones could not get drilled ones where do you get the drilled ones
Hi Pierre,
Have you already bought the fronts as well??
