Advice on Coil or Condenser
No More Landy
What model do you have?: Beetle 1971
Has thanked: 23 times
Been thanked: 6 times
Germany
Re: Advice on Coil or Condenser
Post by No More Landy »
Dawie wrote:Pin 1 on Bosch coil equals negative on Huco. Positive same as 15 on Bosch. Clean the Bosch coil and try again.
Carb fuel level around 19.5mm down from mating surface.
Thanks. Added an additional 1mm aluminium washer to existing washer and seems better. Haven't measured yet.
Have to test her when this storm subsides and report back
Sent from my SM-A326B using Tapatalk
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
No More Landy
Germany
So I think I actually have a burnt valve.
Sounds like backfire through the intake and it's not timing or valve clearance.
Oh well. Have a spare set of new heads I bought from Tony Z that I better get ready to fit.
Sent from my SM-A546E using Tapatalk
1971 Beetle
2021 Polo tsi
Been thanked: 487 times
check for vacuum leaks.
Spray quickstart around every seal and gasket on the inlet system with the car idling. If the sound changes, you've found it.
Been thanked: 100 times
If you have a twinport, make sure those intake rubber boots are sealing 100%. I have a 1300 twin port with the intake manifold and end casting diameters being slightly smaller than the 1600. The only boots I could get locally was for 1600, so it’s a bit of a struggle getting a proper seal. I resorted to using some sealant and all is fine now. You mentioned 31 Pict 3, which is only used on 1300 DP, AFAIK.
No More Landy
Germany
All good on intake for sure.
1971 Beetle
2021 Polo tsi
