Page 2 of 4
Re: Camber Compensator Suppliers
Posted: Tue May 05, 2020 9:49 am
by Haans
Posted: Wed May 06, 2020 6:38 am
by Bugger
What are you actually looking to achieve?
By your previous post you are looking for a Rear anti roll bar set up
If you go around
Say right hand corner
The pressure forcing left wheel in is used to lift rhs wheel inwards to keep body as straight as possible
My Squat bar is more for Hard pull offs
Posted: Wed May 06, 2020 5:49 pm
by Haans
Posted: Wed May 06, 2020 9:51 pm
do some reading on what a rear anti-roll bar does to a swing axle car.
Yes you can buy them. From what I've read, I'd rather not.
Posted: Thu May 07, 2020 6:43 am
by Bugger
The track racing guys modify and upgrade the existing Z bar
I did the same for my Bloodhound bug when we went to Hakskeen pan
Main reason aswell was to eliminate the rear wheels tucking in if I would have turned sideways losing it on the Sand
I managed a 215Km/h
On the pics you can see how the rear wing works very well with the Airflow of the Dust
Posted: Thu May 07, 2020 9:27 am
by V6 Capri
Is it my imagination, or does the car sit quite low at speed?
Wing works great though.
Posted: Fri May 08, 2020 3:35 pm
by John Alves
has any tried something like this?
Posted: Fri May 08, 2020 3:51 pm
by John Alves
or something like this?
Posted: Fri May 08, 2020 5:12 pm
by Haans
Herman has a strap on the fastback,.....just before the shock. It seems to do the trick
Posted: Fri May 08, 2020 5:49 pm
If you want the car not to sit down like a lam dog when pulling away, you set up the spring or fit coil overs.
If you do not want the wheels to fold under the car on a sharp turn, then fit straps. or a strong bunggy cord from top shock mount around axle and back to shock mount.
If you want to have fun or are a windgat with your Aircooled, then fit both
With the extra power I have in my Fastback, my Fleetline as well as my 52 Beetle, I have fitted coil overs on all 3 at the back.
OMO
Posted: Mon May 11, 2020 12:33 pm
by Haans
Herman,....want to look windgat and more over safe from not rolling over.
Coil overs,....can you be more specific ?
Posted: Mon May 11, 2020 8:58 pm
Volk spares sell them and some others as well.
Posted: Mon May 11, 2020 9:39 pm
by JP_Pentz
retrovan wrote: ↑Mon May 11, 2020 8:58 pm
Good day Hans they usually sell them for beach buggies
R3500 for set of 2.
Posted: Tue May 12, 2020 5:30 pm
by Haans
Thanks gents. My budget is being closely scritinized by you know who,
shocks will have to wait
Posted: Sat Jul 11, 2020 4:59 pm
by Simmy
I have been thinking about this for a bit and decided to go my own way with a CC. However, I want it to attach to the forks, as opposed to the gearbox - like the original EMPI's used to do. So here is idea at this stage (including a mid-mount):
The plan is to have the brackets laser cut from 5mm mild steel, and then welded up together as shown (Might add an extra gusset in the middle). To fit it to the forks, my plan is to drill into the forks and install steel M8 rivnuts which allow the thing to be bolted to the underside of the forks. Everything else works exactly the same as the other types of CC. Just need to find a suitable leaf spring and some straps for the swing arm tubes.
As far as I can tell, the forks are hollow, and are far enough away from the gearbox mounting frame bolts, so shouldn't present a problem for drilling.
Any thoughts from the forum?
